oil pressure check
Old Nov 28, 2005 | 10:12 PM
bob arrington's Avatar
bob arrington
oil pressure check
where do you check oil preassure on the block other than the oil sending fitting?, thanks, Bob
Old Nov 28, 2005 | 10:18 PM
Bear 45/70's Avatar
Bear 45/70
On an FE you don't.
Old Nov 28, 2005 | 11:32 PM
ford390gashog's Avatar
ford390gashog
you don't like stated above. the sending unit needs to be unscrewed to cehck the pressure.
Old Nov 29, 2005 | 12:10 AM
Bear 45/70's Avatar
Bear 45/70
Either that or install a "T" and run both a mechanical gauge and the sender for either the elecronic gauge or idiot light.
Old Nov 29, 2005 | 12:12 AM
ford390gashog
yes that is doable. but on a fe it can be a very tight spot . it gets worse if you have the oil filter mount that points to the side and have power steering then it becomes a PITA.
Old Nov 29, 2005 | 12:45 AM
Bear 45/70's Avatar
Bear 45/70
With a horizontial filter I like to put a 90 degree elbow on, then an extension and put the "T" on out where it isn't so hard to install, at least you can see it. On the race car we ran a braided hose up to the inner fender and mounted everything there.
