crane 904?
Old Nov 30, 2005 | 05:59 PM
rusty70f100's Avatar
rusty70f100
I do not recommend shimming, unless all the stands are shimmed the same on each side. Since the FE uses a common rocker shaft per head, shimming one stand and not another causes the rocker shaft to bend. Not good.
If you're looking for a 100% guaranteed way to assure any cam will work with a non-adjustable valvetrain, you're not going to find it. I'd get the cam, pre-assemble it, check preload, and go from there. And budget for either the adjustable setup or custom pushrods.
On the springs, Crane recommends part number 96801.
Old Nov 30, 2005 | 06:03 PM
73F100*8Mile's Avatar
73F100*8Mile
ok now i'm getting some common opinions-thats what my machinist said. thanks again for your patience kurt! you sould like a 50 year old been there done everything kinda guy-hard to believe your only 24. thanks again and i assure you i'll be back with more to try and challenge your knowledge.
Old Nov 30, 2005 | 07:15 PM
73F100*8Mile
ok kurt i'm gonna have a hard time swallowing a $500 valve train but i want this motor to be right for a long time. i was looking at one of your post's from back in late october when we were talking about my "$1000 390". you said a good setup for me would be as follows:
-crane 343941-$109
-lifters-$48
-pushrods-$45
-rocker arms-$209 ( i think i can get those a little cheaper from napa)
-valve springs-$91.99
-balancing of 390 crank/rods and 360 pistons-$220 from my machinist
ok so we're looking at a $500 valvetrain and $220 rotating assembly which makes $720. this leaves me with $280 for my carb which i've found one that will cost $170 and is a Holley fact. rebuilt. now i'm down to $110 and keep in mind i have since then found a $25 4v intake from the yard. this is a dangerous question but what would you do with the other $110 if you could spend it?? i'm gonna get headers later on as an experiment to see what my 390 unleashes from stock manifolds to headers too. so would you go with? a better timing gear setup, aluminum pulleys??? uh oh woops i just remembered i'm gonna need new rings...got any idea how much those things will run 40-60?? also if you're wondering, my dad got me the 390 crank/rod setup for my birthday and christmas combined and he threw in the new bearings and gasket set so thats where thats coming from. thanks again for your knowledge-hope this made sense!
Old Nov 30, 2005 | 07:20 PM
73F100*8Mile
also some basics-
-what plugs would you run with this setup-just regular autolites or would i need a hotter plug?
-what weight oil would you recommend? i've always run 10w40 in my 360 and i live in northeast ga where it rarely gets below probably like 20 of which i just won't drive unless i have to.
-should i go with the coldest thermostat to help the motor? i've got a 4row modine with the steel plate riveted to the back of my waterpump impeller to reduce cavitation and currently a 180 therm.
thanks once again!!! this is too much info to just be for free!
Old Nov 30, 2005 | 07:34 PM
rusty70f100
I cant really play accountant on here. That gets old, really quick.
First for the $110. How much machining is already done? Is the block bored over, cam bearings installed, freeze plugs installed, oil gallery plugs installed, valves ground / replaced as necessary, valve guides checked and replaced as necessary, and the rod small end bushings replaced? Machining could kill your budget right here and now if it's not done yet and you're already down to $110.
Now the questions:
-Dont know yet. We haven't settled on a build.
-Run 15w40 or 10w30 diesel rated oil. It has the proper additives to protect the cam.
-ABSOLUTELY NOT!!! The colder the thermostat, the more cylinder bore wear you will have. Run a 180.
Honestly, and I'm not trying to be hard on you or anything, but I'd take some of the money and go buy some books. I suggest:
"How to Rebuild Big-Block Ford Engines" by Steve Christ, ISBN # 0-89586-070-8
"The Step-by-Step Guide to Engine Blueprinting" by Rick Voegelin, ISBN # 1-884089-26-7
"Super Tuning and Modifying Holley Carburetors" by Dave Emanuel, ISBN # 0-931472-08-3
You'll learn a lot and I think you'll have much better results with your engine rebuild. Best investment you can make at this point IMO.
Old Nov 30, 2005 | 07:46 PM
73F100*8Mile
ya everything you mentioned has been reworked. thanks again for the info, your honesty and patience!...i wanna do this right obviously!! ya i'll go be a bookworm for a while and see what i can learn from that...also with my dad learning it with me that'll make it that much easier as he has much more experience than i. thanks again kurt for everything!
chrisbrady498
Apr 25, 2015 03:56 PM
mkrog
Oct 29, 2011 07:07 AM
low 66
May 2, 2011 07:42 PM
charles jones
Nov 10, 2006 07:45 PM
f100 guy
Jul 20, 2004 03:12 AM
