84 F150 info needed
Old Nov 27, 2005 | 09:44 PM
JD717's Avatar
JD717
84 F150 info needed
I'm looking at an 84 F150 for a second truck, but I need some info, like how to tell what engine it has in it, the tranny, and any problem areas on such a truck. I'm going on tuesday to look at it, and check out alot of it, before I set anything on it in stone.
Old Nov 27, 2005 | 11:29 PM
sierraben's Avatar
sierraben
The VIN will tell you the engine code (eight digit).
The tenth digit should be the letter "E" (1984)
The vehicle data label will tell you pretty much the rest.
Not sure where it's located on a '84.
My 81F150 is on the drivers side lock pillar post.
Maybe someone out there has the codes for a 84 F150.
Good luck.
Old Nov 28, 2005 | 03:34 AM
srercrcr's Avatar
srercrcr
I've had my 83 since it was new, and can honestly say these trucks have few inherant problems. Good maintenance will keep u out of trouble.
The heater blend door (mixes A/C with heated air) is a common Ford problem.
Old Nov 28, 2005 | 10:57 PM
shop dawg's Avatar
shop dawg
anyone know where to obtain a steering colum for 83 f150
Old Nov 28, 2005 | 11:58 PM
sierraben's Avatar
sierraben
Have you thought about rebuilding yours?
Trying to find one that's not all beatup and worn could be difficult.
Old Nov 29, 2005 | 02:23 AM
JD717's Avatar
JD717
Ok, today I shall look at it, and shall see the truck. if I like it, my ranger goes up for sale, and I shall have an F150.
ByronMc
Jan 13, 2014 11:37 AM
VAfarmboy
New Member Introductions
Jul 7, 2009 08:48 AM
justshootme84
16
May 7, 2008 10:03 PM
Rick_Ford
Feb 8, 2004 12:29 PM
redneckdieselmechanic
Car/truck Buying Advice
Apr 26, 2002 07:19 AM
