Water Spot Removal
Old Nov 27, 2005 | 03:11 PM
Bigdawgkp's Avatar
Bigdawgkp
Water Spot Removal
Does any one have any recommendations on how to remove water spots from automobile windows?
Old Nov 28, 2005 | 02:57 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I'd use very fine steel wool (000) and take my time with it. If the vehicle is old and of low value/rough body/etc, I'd be more aggressive and give CLR a try.
Old Nov 28, 2005 | 03:27 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Nov 28, 2005 | 01:57 PM
PW01's Avatar
PW01
vinegar should do the trick
Old Nov 28, 2005 | 03:48 PM
Bulldozer's Avatar
Bulldozer
Dura Gloss make a cleaner called new glass that works great you can pick it up at NAPA http://www.duragloss.com/product.asp?pid=303
Old Nov 28, 2005 | 06:11 PM
Gervis's Avatar
Gervis
Ammonia with water or rubbing alcohol should cut the spots. Foam cleaners are easier to use and seem to have a higher ammonia content without being smelly. They leave window glass an excellent shine.
Old Dec 9, 2005 | 09:04 PM
1998TA__1991RS's Avatar
1998TA__1991RS
i had the same problem with my 05 crew, i work at the ford dealership detailing so i used some non diluted chrome acid and it took it right out, better than anything i have ever used
kenneBF250V10
Appearance & Dress-Up
68
May 17, 2013 01:02 PM
CountryD
6.7L Power Stroke Diesel
22
Apr 1, 2013 11:11 AM
lawnspecialties
Crossovers
Aug 9, 2009 02:57 PM
Vinheyhey
2004 - 2008 F150
16
Apr 8, 2006 07:08 PM
cow_boy104
Jul 8, 2003 04:13 PM
