Bronco II Ford Bronco II
ignition switch help
Old Nov 27, 2005 | 10:02 AM
smittyboy's Avatar
smittyboy
Hi I am new here.My son lost the only key to his 86 Bronco 2. We took out the steering column & took it to a locksmith,he could not get an impression to make a new key. He said to drill out the old one. Well we drilled out what seems to be the pins that the key fits around but it will not turn to run so we can get it out any ideas? Thanks in advance.
Old Nov 27, 2005 | 01:34 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Nov 27, 2005 | 08:17 PM
Ken00's Avatar
Ken00
From the 1995 manual....
Lock Cylinder Non-Functional
Removal
NOTE: The following procedure applies to vehicles in which the ignition lock is inoperative and the ignition switch lock cylinder (11582) cannot be rotated due to a lost or broken key, unknown key number, or a cap that has been damaged or broken to the extent that the ignition switch lock cylinder cannot be rotated.
Disconnect battery ground cable .
Using channel lock or vise grip pliers, twist cap until it separates from the ignition switch lock cylinder .
Remove lower shroud as outlined in this section under shroud removal.
*****-punch pin and drill out with 1/8-inch bit. Do not drill deeper than 13mm (1/2 inch). Put a piece of masking tape 13mm (1/2 inch) from tip on bit. Take care not to damage housing.
Using a 3/8-inch diameter drill, drill down middle of ignition lock key slot approximately 44mm (1-3/4 inch) until ignition switch lock cylinder breaks loose from breakaway base of ignition switch lock cylinder . Remove ignition switch lock cylinder and drill shavings from lock cylinder housing.
Remove column lock gear retainer, steering column lock housing bearing (3E700) and steering column lock gear (3E717) . Thoroughly clean all drill shavings and other foreign materials from lock cylinder housing.
Carefully inspect lock cylinder housing for damage from the above operation. If damage is apparent, lock cylinder housing must be replaced.
Installation
Replace lock cylinder housing, if damaged.
Install steering column lock gear , steering column lock housing bearing and column lock gear retainer.
Install trim and electrical parts.
Install new ignition switch lock cylinder as described in this section.
NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
Connect battery ground cable .
Check operation of lock cylinder.
