Oil Leak
Old Feb 13, 2002 | 11:42 AM
DutchmanAZ's Avatar
DutchmanAZ
Oil Leak
I've noticed that I'm losing a lot of oil in my '76 F150 4x4 (FE 360).
It seems to drip off the starter, but I can't see the origin of it.
I've replaced the valve cover gasket on that side (passenger's), but I still get it.
Any other ideas where to look?
Thanks!
Old Feb 13, 2002 | 12:16 PM
jowilker's Avatar
jowilker
Oil Leak
It is either the valve cover or the intake leaking. Just because you replaced the valve cover gasket, doesn't mean that it isn't leaking, took me 4 sets before I got it right. You need to put the cover on the edge of a piece of wood 20" or so long and pound it straight and flat and then don't over tighten the covers. The intakes are also big on leaking, pull it seal it and reset it. It is an all day job.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Feb 13, 2002 | 12:40 PM
dfisher1's Avatar
dfisher1
Oil Leak
dutch,
Don't forget the rear crank seal! Look on the tranny bell housing and see if its covered with oil or not. If not, it's probably the rear crank seal. That means dropping the oil pan and the rear cap.
Good Luck, Have Fun.
KingFisher
Old Feb 13, 2002 | 01:06 PM
BB's Avatar
BB
Oil Leak
Go to a DIY car wash with the high-pressure spray and blast everything on the rear of the engine. By the time you drive home the fresh leak should be visible enough to track down.
Old Feb 13, 2002 | 01:44 PM
DutchmanAZ's Avatar
DutchmanAZ
Oil Leak
Thanks for all the responses...I'd hate to have to pull the intake again, just got it back on after replacing a head gasket. Wouldn't an intake oil leek result in a serious vacuum leak (thus a real rough running truck)?
I know my rear main is leaking a little, but how would that explain oil dripping from the top of the starter (out where it gear engages the flywheel)?
Thanks again
Old Feb 13, 2002 | 07:40 PM
DrFord's Avatar
DrFord
Oil Leak
my 390 leaks like a faucet from the intake corners. oil is dripping from the starter constantly. But the truck runs great.
Old Feb 13, 2002 | 08:03 PM
79Supercab's Avatar
79Supercab
Oil Leak
