Dana Yoke
I have a 75 F-100 that a previous owner converted to 4wd. It has a 4"lift, 460, np435 and I believe a Dana 21 T-case. The driveshaft and pinion angle were not set up correctly and when The front u-joint let go it busted the front yoke. When I called a d-shaft builder he told me what the dimensions were for the yoke and u-joint needed to hook up a CV equipped driveshaft. The broken one is not it. My questions are, Can I find a different yoke to fit this, what might be a donor and what should I ask for. Any and all comments, advice and or suggestions would be greatly appreciated.
Thanks,
Al
Ryan.
78 F250 Ranger XLT Supercab 4x4
460, C6, NP205, D44, D60, 4.10's, 33x12.50x16.5 tires
71 Bronco, 302, C4, PS, PDB (1/2 complete with rebuild)
