4v intake found!
Old Nov 26, 2005 | 09:28 PM
73F100*8Mile's Avatar
73F100*8Mile
Thumbs up 4v intake found!
went to the yard today and found a '57 galaxy with what i assumed was a 352. i don't think they made anything any bigger back then right? anyways i was hoping for an "s" intake off a 390 but this 4v was in good condition (no stripped threads, still bolted on so i new it wasn't warped, and hadn't had too much rain). the intake reads 5F24 and also C5AE9425C. question is i was just wondering how this one would perform any better or worse than the "s" intake or any other info would be great. thanks
Old Nov 26, 2005 | 09:50 PM
Putt's Avatar
Putt
Well no ID in my books, but it is not original to the '57 Galaxy. The C5AE casting denotes a '65 production intake for Ford passenger cars. The 5F24 means the casting date was June 24, 1965.
Old Nov 26, 2005 | 10:03 PM
73F100*8Mile
well it could be that i read the sticker wrong and it said '67 or maybe they put '57 and ment '67...who knows...thanks and what book are you using for this so i can get one?
Old Nov 26, 2005 | 10:14 PM
Putt's Avatar
Putt
How to Rebuild your Big Block Ford by Steve Crist and Ford Performance by David Vizard, both should be available from MotorHaven(site sponsor).
Old Nov 27, 2005 | 12:17 AM
Bear 45/70's Avatar
Bear 45/70
No Galaxies in '57. The Fairlane was the biggy then.
Old Nov 27, 2005 | 02:06 AM
gtex's Avatar
gtex
And, the FE showed up in 58, right?
Old Nov 27, 2005 | 05:38 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
If it is indeed a 67 intake....it should have the same port size as your 73 heads in your truck (if the heads havent been chaged to the early heads with larger port) Mid 66 and prior....Had the larger ports....JMO
Russ
Old Nov 27, 2005 | 06:27 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
It's a 65-66 X code 352 intake. Iron 4 bbl and 5F24 is the date code of 65/June/24th. It's a lowriser intake with lowriser ports. Not a bad find.
G.
Old Nov 27, 2005 | 06:43 AM
RapidRuss's Avatar
RapidRuss
Well then G, since you ID'd the intake as being 65/66 its got the big ports and wont match up to his later heads on the 73 if he indeed does have 73 heads on the truck?
Russ
Old Nov 27, 2005 | 07:07 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Russ,Correct it will not match the heads. That's not to say it can't be used but it's not the best performance combination.
And Greg yes the FE arrived in 58.
G.
Old Nov 27, 2005 | 02:07 PM
fordeverpower's Avatar
fordeverpower
Well that port mismatch isn't anything that cant be fixed.
Old Nov 27, 2005 | 05:26 PM
73F100*8Mile
so should i match port my heads to match the intake or should i just put this on there the way it is ...i have D2TE heads by the way. thanks
Old Nov 27, 2005 | 05:35 PM
fordeverpower
open the head up about a 2.2 inches, then mock fit the intake to the head and look through the valve seat area to make sure the intake port is bigger than the intake.
Just bolting the intake on is an extremely bad idea! Kinda like driving a truck that is 6 feet wide through two trees that are 5 feet apart.
Old Nov 27, 2005 | 07:21 PM
73F100*8Mile
do you recommend any particular tools used to port the head? i have an electric dremel so i'm hoping to just get heads for it and use it for the whole project but if theres a more efficient way then i would like to do that. basicallly i should just port my head to the size of the gasket right? can't go any bigger and i don't think i'd wanna go any smaller. should i smooth out the inside of the intake manifold right towards the end of the port at the head too? thanks again
Old Nov 27, 2005 | 07:33 PM
fordeverpower
yeah, carbide bits are the best way to get the job done. But stones will work with time. The blue ones work fairly decent, while pink work for bowl work. The gasket match is up to you, I suppose you use standard fel pro gaskets, they are for 428 cj size, 2.43 by 1.43.
As for the intake it should measure about 2.16 by 1.10 ish. Not a lot of need to work the runner unless you are looking for max power from these parts. If so I recommend tapering the top 4 holes to match the carb gasket. Just round them a little as if you were making the ideal cylinder head seat.
