Car, transmission, shifter question
Old Nov 26, 2005 | 03:10 PM
learpilot's Avatar
learpilot
If this is the wrong place to ask just tell me where good forum is that covers ford cars. I restored a 1963 ford galaxie 500 xl that has a 4 speed manual trans. sometimes, actually often, if I'm not paying attention, when I shift gears the trans will hang in gear even though the shift lever moves, causing me the have to stop and realign the shifter with the trans. How can this be corrected if possible using the orginial shift lever ( it has the lift gate to allow reverse) or must I change to an after market shifter such as Hurst. Does anyone know it there is such a thing that will work in this application? Thanks
Old Nov 27, 2005 | 11:30 AM
Earl's Avatar
Earl
You might try this question over in the transmission forum. I think it's OK as long as we don't get off-topic in the thread.
Old Nov 27, 2005 | 01:03 PM
WillyB's Avatar
WillyB
If it were a top loading truck transmission it would be caused by warn shift fork in the transmission, or some related part. Does the shifter go directly into the case or is there some linkage between the shifter and the trans?
Old Nov 28, 2005 | 07:31 PM
learpilot's Avatar
learpilot
***** B, there is linkage involved, thaks
Old Nov 29, 2005 | 11:42 AM
51ford fan's Avatar
51ford fan
Here is a few of my fovorites links besides the FTE forum
http://www.shoeboxford.com/
http://www.fordbarn.com/earlyv8/forum03/
http://www.jalopyjournal.com/forum/index.php?
http://groups.msn.com/FordFlathead1932to1953
Old Nov 29, 2005 | 12:15 PM
AXracer's Avatar
AXracer
I once had that type problem with a floor shifter, where it would lock between gears while shifting. It was due to wear slop in the shifter itself that would allow it to come out of the one arm in neutral without engaging the next arm. You may be able to rebuild the shifter but replacing it with a Hurst would be the best solution.
Old Nov 29, 2005 | 05:49 PM
hiball3985's Avatar
hiball3985
the original shifter on those cars weren't great when new and they get really bad when old and worn....you probaly have a BW t10 trans, I think Hurst still has shifters avaliable for them..it well worth the money for the diffence in how they shift..think I paid about $125 for the last one I bought
obey_your_master
Apr 3, 2007 07:35 PM
jbamf
1966 - 1977 Early Broncos
Apr 28, 2006 01:01 AM
kf4lgeacj2
Mar 6, 2005 09:55 PM
hca
Jan 9, 2005 02:56 PM
ratwell
Oct 25, 2002 12:03 PM
