58dotneck
Old Nov 26, 2005 | 09:56 AM
58dotneck's Avatar
58dotneck
58dotneck
turn signal problems.
when I turn on the right turn signal the left and right rear flash. So does the left rear marker light. rear running lights dont come on with the headlight switch. Everything in front works fine. brake lights ,4 ways ok. Any ideas?
Old Nov 26, 2005 | 10:39 AM
daszanto's Avatar
daszanto
Is this for your '87 F-350? I had a similar problem with my jeep, turned out to be a bad aftermarket trailer harness wiring splice connector. If you have one, unplug the splice connector and bypass it and see if it solves the problem.
Old Nov 26, 2005 | 10:46 AM
Neb86's Avatar
Neb86
Check your rear bulbs first. A shorted bulb, one where the filiment has broken and is laying on the other filiment, would cause that problem. I've seen shorted bulbs cause all kinds of weird problems. I had one cause the dash lights and radio display to light up everytime you stepped on the brake!
Old Nov 26, 2005 | 02:24 PM
Piffery1's Avatar
Piffery1
Make sure all of the bulbs are of the correct type and inserted properly in the sockets. It's possible to get them in wrong even though they're not supposed to go in, especially with the softer plastic sockets. Can cause some pretty strange symptoms.
Old Nov 26, 2005 | 06:44 PM
58dotneck's Avatar
58dotneck
Smile turn signal problem
checked all bulbs sockets grounds etc. all ok. Found a melted bundle of wires under drivers floorboard.fixed that and got a whole new nightmare. dash lights flashing with r turn. dim brake lights, no turn with ign. on. guess what found some more melted wires by the right rear tailight. fixed that and everything is fine. what a mess. I'm going to re-wire the whole back of the truck next week.
thanks for the input
58dotneck
thatsrealnice
16
Jul 31, 2020 06:00 PM
1978f-250
Jan 21, 2015 03:35 AM
BCHauler
1997 - 2003 F150
Dec 1, 2012 08:01 AM
lestro
1997 - 2003 F150
Jul 28, 2010 03:43 PM
Rich Stenzel
Electrical Systems/Wiring
Jan 4, 2004 01:49 PM
