oil pan question
Old Nov 25, 2005 | 11:16 PM
7FORD2's Avatar
7FORD2
Question oil pan question
ok guys does anyone know who makes a rear sump oil pan for a 351 cleveland or can i use one off another engine if so what one? thanks guys
Dustin
Old Nov 25, 2005 | 11:58 PM
texan2004's Avatar
texan2004
I have one that I was told came from a full size van.
Old Nov 26, 2005 | 11:38 AM
grclark351's Avatar
grclark351
factory Ford 351M and 400 rear sump oil pans will fit the Cleveland, they came on millions of trucks and vans. you'll prolly see them on Ebay, you can go junkin, or they might even still be available from Ford? you'll need the correct oil pump pick-up tube, the main bearing cap bolt with the mounting stud on it and the nut too. several aftermarket makers have them too if you want to spend the $$$ for a fancy high capacity pan, Canton is popular, Moroso too.
