Intake pre-heater.
Old Nov 25, 2005 | 06:57 PM
plow/truck's Avatar
plow/truck
Intake pre-heater.
<O</O<O</O
I think it’s called an intake pre-heater. The thing-a-majig that hooks to the heat shield that allows warm air get into the air cleaner/carburetor.
Anyway, is it supposed to be closed normally, then open when it gets hot.
Or is it normally open, then close off when very cold, allowing warm air to flow in until warm.
I tried to test it by putting it in the deep freeze, but no workie.
I jerry-rigged the thing to allow more warm air to flow in. Is this a good idea?
Most people leave this un-hooked. But I only drive this a few time a year, and it’s always cold!
Plow/Truck
Old Nov 25, 2005 | 08:20 PM
ceetwarrior's Avatar
ceetwarrior
Just take it out. More air the better. Even if it is warm. If you want extra warm up heat, get a heated spacer plate for the carb.
Old Nov 25, 2005 | 09:00 PM
FEmtnmax's Avatar
FEmtnmax
A friend used to fly planes - military in Vietnam, commercial aircraft, crop dusters. He said the best way to avoid carburetor icing is to provide preheated air to the carburetor. He runs carb preheat on all his rigs. Some of his rigs he runs a choke type cable to the flapper valve so he can turn it on-off. The Ford flapper is in the closed position (letting in heated air only) until the temp sensor on the valve warms up enough to open the valve to let cold air in. I thinks its better to have the heated air rather than use the exhaust heat crossover that gets the intake manifold so hot you can't touch it.
Old Nov 26, 2005 | 09:38 AM
plow/truck's Avatar
plow/truck
Thanks FEmtnmax,
Your information was very helpful.
Sounds like I did ok by pulling on the spring to close off the intake to allow more heated air in. I didn’t completely close off the cold air, just in case its not working. Probably not a good setup for running on a daily driver.
Is the pre-heater replaceable or available?
Plow/Truck
Old Nov 27, 2005 | 09:05 PM
FEmtnmax's Avatar
FEmtnmax
That ranch friend leaves the flapper set to hot air for the entire winter. Its not like the heated air is so hot it'll damage something. Maybe watch the air filter element for signs of excess heat. I want to get my hot air flapper working to draw air from around headers. Haven't done it yet. The old '67 truck kinda gets pampered in the winters to avoid road salt, so I don't drive it much. Its kinda like working on farm equipment. Winter is for tear down and making improvements.
websurfer
19
Feb 21, 2024 06:19 PM
jpj64
1983 - 2012 Ranger & B-Series
25
May 24, 2010 08:58 PM
tjc transport
Oct 30, 2007 07:04 PM
d60d70
Modular V10 (6.8l)
18
Aug 13, 2007 09:40 AM
doctorolds
Jun 1, 2007 04:49 PM
