what r my options.....
Old Nov 25, 2005 | 03:23 PM
merlynr's Avatar
merlynr
Question what r my options.....
I have a 71 F350 dually and need the e brake cables from cab to rear wheels. It splits from one to two on the crossmember behind the cab and I was wondering which vehicles would be compatible as a donor? Is F150-250 the same, and what years? Thanx in advance
Old Nov 25, 2005 | 09:04 PM
Ford_Six's Avatar
Ford_Six
If you have the frame mounted forward auxilary tank, you will need a cable for that setup. The cables for F-250s and F-350s should be the same, as long as it's the same wheelbase truck.
Old Nov 26, 2005 | 12:25 AM
Fomoko1's Avatar
Fomoko1
Try a larger parts store, I just got e-brake cables for my 69 F100 from an after market supplier. The 1 ton cables maybe harder to find but it doesn`t hurt to check to see what is avaible.
