1978 - 1996 Big Bronco
manuel hubs
Old Nov 25, 2005 | 03:08 PM
96eddie5.8's Avatar
96eddie5.8
manuel hubs
i finally bought the warn premium hubs and the conversion kit...but,
i cant seem to get the locking ring off the outter piece of the automatic hubs that are on the truck now. this piece im refering to is the ring that locks the inner part of the hub into the axel. It is also the last thing to be put back on before the outter coverning of the warn premium.
does anybody have any good ways to get this ring off without breaking it. thanks
Old Nov 25, 2005 | 03:38 PM
96eddie5.8's Avatar
96eddie5.8
well, monkeying around got it off. but is there a easy way to do it, thanks.
Old Nov 25, 2005 | 06:56 PM
fishin machine's Avatar
fishin machine
I found that a scribe w/ a 90 degree bend it it works well. Just put it in behind the spring and work it out. Think everybody has there own way of pulling these things.
Old Nov 26, 2005 | 12:36 AM
oldbluebronco's Avatar
oldbluebronco
Are you talking about the locking ring "washer" or the inner Axle Nut. If you are talking about the nut you need a spanner Socket. It looks like a Cup with four posts on it. if you are talking about the washer, i used the 90 degree scribe that Fishin Machine talks about.
Old Nov 26, 2005 | 11:57 AM
96eddie5.8's Avatar
96eddie5.8
how do you get the wheel retaining nut out from the old warn automatics, is there a different spanner nut socket? the four prong spanner does not fit in the warn automatic. Thanks
Old Nov 26, 2005 | 01:16 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The wheel retaining nut is behind the lockout hub. Once the lockout is completely removed the four prong spanner will fit. Ford used the same nut for every 4x4 they made until the sealed bearing assembly's came out around 1998.
Old Nov 26, 2005 | 06:32 PM
oldbluebronco
Right, behinfd the first nut is a washer use the 90 degree scribe to pull that out then the spanner nut will fit over the last nut.
Old Nov 26, 2005 | 10:45 PM
96eddie5.8's Avatar
96eddie5.8
well, i have the spanner nut and when i put it in the hub to try and remove the origional wheel retainer, it neither catches nor seems the right size to fit on anything. i know its the right socket becuase it fits into the groves in the new manuel converson kit that i have. the instructions in the converson kit show that the wheel retainer needs to come off.(from the origional). it looks like a bigger socket could be used to get around the wheel retainer, but i dont have one or know if i even need one.
Old Nov 26, 2005 | 11:17 PM
oldbluebronco
HAve you removed any of the nuts from with in the hub. or are you trying to remove the first of two. Not all the sides are even so turn it until it slips on. I had the same problem at first too. if it fits the new manual nus then it should fit the old hardware. That is all i used when I changed mine.
Old Nov 26, 2005 | 11:38 PM
MinnManBroncoFan's Avatar
MinnManBroncoFan
I take it your going to converting the 3 bolt to the 5 bolt right ?
The nuts have a bunch of holes in them I just used a needle nose plyers.
There's a spring style lock in the keyway that has to come out first.
Just pull it out towards you.
The big c ring that holds the hub in is a pain to get out because the auto hubs hang out so much more then the man.
Take your time you get it.
Old Nov 27, 2005 | 02:26 AM
stevef100s's Avatar
stevef100s
Then why did I need to use one wrench on a 79, and a different one on a 96? You can trust me when I say I didn't need to be buying any tools at the time. I had 2 other Ford owners trying to help me, but they had 94 or earlier auto hubs. They came to the same conclusion as me.
Old Nov 27, 2005 | 01:25 PM
MinnManBroncoFan
The nuts are Different but come out ez.
Like I said I just used a needle nose.
Old Nov 27, 2005 | 07:03 PM
96eddie5.8's Avatar
96eddie5.8
to clarify, i am trying to remove the wheel retainer nut, or the nut which holds that on. i have already taken off all of the other stuff, including all of the c rings. i am trying to convert 3 screws to 6 which are on the warn premiums. i have a 96 eddie bauer. if that helps any thanks
Old Nov 27, 2005 | 07:45 PM
Blue'87GT's Avatar
Blue'87GT
If you are referring to the large nut inside, you need to use a four prong socket, which you can get at any autoparts shop. FWIW, there are two different sizes of this socket, if the one you have doesn't fit, you need the other size.
Old Nov 27, 2005 | 07:50 PM
96eddie5.8's Avatar
96eddie5.8
i have the four prong spanner socket, but that only fits onto the new bolts for the warn premiums(i cant even find any holes for a pronged socket), im looking for what the equiviliant of the four prong socket for origional equipment is, which i believe are warn automatics. ?? it seems like it is just a large socket, but i dont know what size??
