Throwin Codes
Old Nov 25, 2005 | 02:59 PM
mynarepairs's Avatar
mynarepairs
Throwin Codes
Help! My 96 F350 Powerstroke Is Gonna Give Me A Stroke.
It Starts And Idles Fine, After I Drive It For A Short Distance It Looses Power But Doesnt Die. The Check Engine Light Comes On. If I Shut It Off And Restart The Light Goes Out, And She Runs Fine , For A Little While, Then Same Thing Again. Had The Codes Pulled, Got One P0113 Iat Sensor1 Tried A Different Sensor , No Change. The Other Code Is A P1211 Inj Cntrl Press (engine Running). Ive Changed The Air & Fuel Filters And Even The Oil, Which Has Been Dello For The Five Plus Years Ive Had The Truck. It Will Idle All Day Long , Ive Even Run The Engine Up To 2000 Rpm In Park, No Problem, It Seems Like The Engine Has To Be Under Load And When I Accelerate To About 35 Or 40mph Thats When The Check Engine Light Comes On. Any Ideas Out There?
