have some questions?
Old Nov 25, 2005 | 03:09 PM
puffer's Avatar
puffer
Question have some questions?
I have a few question that needs your guys help?
how long is a turbo good for miles?
how do you know if its a bad turbo?
whats stock boost on a 96 psd?
how loud would a diesel be with no muffler but full piping?
whats the max boost you can run with a stock fuel system?
does removing of the ebpv increase performance?
thanks you for the help
Old Nov 25, 2005 | 04:02 PM
barebackjake's Avatar
barebackjake
turbo's life depends on how it gets taken care of i would say on a stock truck that has had clean air and oil to the turbo would last almost as long as the top end.
bad turbo wont get as much boost, can make scraping or squeeling noises.
stock boost level is about 16-18psi
ive got 3 7.3's not one with a muffler, 1 truck has 4" the other 2 have 5" and one of the trucks with 5" is my wifes and it dosnt bother her.
stock injectors only flow about enough fuel to make about 25 psi of boost with real hot programming.
ebpv removal will make a small difference in response and slightly lower egt's
diehardstroker
22
Apr 7, 2020 12:42 AM
rcogs
Oct 17, 2009 06:42 PM
bigdummyford
General Diesel Discussion
Jun 10, 2009 10:23 AM
BittersweetSHO
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Aug 16, 2004 12:12 PM
