HELP! 99 Ranger Problems
Old Nov 24, 2005 | 09:43 PM
cac_84's Avatar
cac_84
I own a 99 Ranger with the 3.0L V6. Recently it has started with a quick jerking/vibration when i try to maintain a constant speed. As soon as i accelerate or decelerate it quits. The engine light is on and the air bag signal blinks the code 27 at me then stays on. I hooked a code reader up to it and it says cylinder 5 is misfiring and gives me an oxygen sensor code. If anyone has any idea on how to fix this or diagnose it i would appreciate some feed back. Thanks
Old Nov 24, 2005 | 10:08 PM
RangerPilot's Avatar
RangerPilot
Mileage, tranny?
Check your plugs and wires, obviously starting on cylinder 5. The 02 sensor is easy to replace and cheap, so you might as well replace it, probably time anyways.
Old Nov 24, 2005 | 10:30 PM
99 ranger bob's Avatar
99 ranger bob
id check the connection on the spark pack too the air bag code is possibly a connection
Old Nov 24, 2005 | 10:46 PM
RangerPilot
I would also suggest disconnecting your battery for 20 mins (the negative side) then driving it and seeing if any of the problems dissapear, especially the air bag code.
Old Nov 24, 2005 | 11:38 PM
cac_84's Avatar
cac_84
close to 110,000 miles, auto trans., 2wd, anything else that may help just ask
Old Nov 25, 2005 | 12:08 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I don't know what your code #'s are, but you need to address the codes in the following order: KOEO, KOER, and CM. Within a given group, you need to address/reapir faults that cause the codes starting with the lowest numeric code. Don't go throwing parts at it until a proper diagnosis has been performed; this often proves to be expensive. Sorry, I don't have the airbag codes here for a 99.
Old Nov 25, 2005 | 06:39 AM
bcjim's Avatar
bcjim
27 = problem with the passenger airbag disconnect (PAD) switch. There have been several threads about this, probably the "off" illumnination light has burned out. If so, the whole switch assy needs to be replaced. (~70$ part)
Old Nov 25, 2005 | 10:01 AM
RangerPilot
Well...do us a favor and don't let anyone in that passenger seat until you get the airbag problem fixed. Does your "off" illumination light work? Could nail this one right here, even though it is a little expensive (and talk about stupid, replacing the whole thing for a stupid little bulb...). cac, welcome to FTE!
Old Nov 25, 2005 | 01:10 PM
bcjim's Avatar
bcjim
Others have posted that the whold AB system is off line if a fault code is diplayed, I cannot verify this.
Old Nov 25, 2005 | 06:43 PM
cac_84's Avatar
cac_84
New plugs and wires solved the problem while driving. Passenger airbag light does not light up. Is there a simple solution to this or do i need to check the whole assembly and bulb first?
Old Nov 25, 2005 | 07:22 PM
bcjim's Avatar
bcjim
Old Nov 25, 2005 | 09:30 PM
ed88's Avatar
ed88
Code 27 is probably a burnt out bulb(passenger side air bag swtch), for which Ford has no replacement. They charge $70 for the whole module. You can pull the module and get a replacement bulb for about $2 at Radio Shack. The bulb does need to be soldered in. If you don't know how to solder ask the person at Radio Shack if they can do it or show you how to do it, if you buy the soldring iron and solder from them. Knowing how to solder is very usefull.
ed88(98 ranger)
Old Nov 25, 2005 | 10:22 PM
probedude's Avatar
probedude
Yep, knowing how to solder is very useful down the road for anything electronic that you want to repair.
Don't count on the Radio Shack employee knowing how to solder though. I'll bet that most of them don't know which end of a screwdriver to hold. Radio Shack's electronic components section keeps dwindling every year.
Ed88, do you have a catalog # for that bulb? It'd make a great 'sticky' on how to replace it.
Old Nov 25, 2005 | 11:15 PM
ed88's Avatar
ed88
I don't have a catalog #. I replaced mine about 2 years ago. I took the mod into them and they matched it up(I remember it was a different color, but worked fine). Radio Shack usually has at least one electronic savy person on their staff. I have been in when that person was not there and I had to come back later.
ed88
What is a great 'stiky'?
Old Nov 25, 2005 | 11:21 PM
probedude's Avatar
probedude
One of those messages at the top of the forum that stays at the top.
I was thinking it would probably go into the "READ FIRST Technical Information" message.
