Help! Reverse lights out
Old Nov 24, 2005 | 07:26 PM
HarleyG8r's Avatar
HarleyG8r
Just recently my reverse lights (both of them) stopped working. Truck is an '03 Expedition. Any idea as to where to look? All other lights, brake lights and signals are functioning fine.
Also, not a huge problem but more of an annoyance. About half the time when I'm starting the truck, all the gauge needles peg out to the high side, stay there for a second, and go back to normal. This also resets the trip odometer. Any ideas?
Old Nov 24, 2005 | 10:10 PM
FTE Herman's Avatar
FTE Herman
On your second issue it sounds like your battery is about to crap out. The behavior you describe typically occurs when the battery has been disconnected and the PCM 'reboots' (so to speak).
Old Feb 25, 2006 | 12:35 AM
Boomer30's Avatar
Boomer30
anyone know the reverse light bulb size on a 01 gator ?
Old Feb 25, 2006 | 01:28 AM
HarleyG8r's Avatar
HarleyG8r
Hit it on the head on the dead battery issue; replaced it and all is well. Still trying to figure out the reverse sensor, though.
Old Feb 25, 2006 | 06:54 AM
projectSHO89's Avatar
projectSHO89
The backup lamps are switched by the Digital Transmission Range (DTR) sensor mounted on the transmission.
Check your owner's manual for the correct fuse (and light bulb) for the reversing lamps. I only have drawings up to '01 which shows the reverse lamp circuit to be protected by fuse F5 in the under-dash fusebox.
Owner's manuals can be downloaded from www.fleet.ford.com if you don't have one.
Steve
Old Feb 25, 2006 | 06:26 PM
HarleyG8r's Avatar
HarleyG8r
Backup lamps work fine. It's the sensor that beeps when there's an obstruction behind the vehicle. I checked all the fuses that could be remotely related to that system, and all are fine. What really throws me for a loop is that occasionally, the system will work fine, but most of the time I just get the message "check backup aid" in the message center.
Old Feb 26, 2006 | 08:20 AM
projectSHO89
Originally Posted by HarleyG8r
Backup lamps work fine...
Gee, I guess I must have gotten confused by "reverse lights (both of them) stopped working".. You didn't say anything about the sensing alarm system for backing up being at issue.....
Steve
leetudor
Jan 7, 2025 05:37 PM
Stebs
Oct 19, 2012 07:19 PM
Superduty.pride
Oct 21, 2011 12:10 PM
gt8684
Sep 18, 2009 03:04 AM
ChrisLambert
Electrical Systems/Wiring
Jul 9, 2004 01:56 PM
