Paste Wax?
Old Nov 23, 2005 | 10:25 PM
imlowr2's Avatar
imlowr2
Paste Wax?
I've noticed on a website that someone applied paste wax to the wood on the bed after it has been varnished, then buff it off and it gives a shine and protects at the same time.. Anyone ever do this and what paste wax is recommended.
Old Nov 25, 2005 | 11:20 AM
fking1's Avatar
fking1
I used regular Carnuba Paste Wax on the bed wood, same stuff as on the truck body.
Fred
Old Nov 25, 2005 | 07:00 PM
imlowr2's Avatar
imlowr2
Fred, is your wood varnished or clear coated? Does it make a difference?
Old Nov 26, 2005 | 02:30 PM
fking1's Avatar
fking1
Mine is Polyurethane marine varnish. Makes no diff if it is clearcoat. Will work just as good.
Fred
Old Nov 26, 2005 | 05:42 PM
5 Star's Avatar
5 Star
Paste Wax
Yes sir I have used it and it works just fine. The one I use is Min Wax, reason being is I tried the Marine Varnish or Urethane, which ever, and had nothing but problems with it.
I am not saying its not a good product, bet my truck got the morning sun, and it lifted it real bad. To the point where the Oak bed turned black from lack of protection.
I stripped it down, was talking to a friend of mine who is into wood working, and he suggested the following.
Boiled Linseed Oil, mixed with Varsol, at a 2 to 1 mix, the Varsol being the 1 part. Paint it on liberally, allow it to dry, then do the second coat with the Linseed Oil straight up, allow this to dry. Finally use the Min Wax, about 2 coats or 3, with a buffing by hand between drying time which is about 10 minutes. This gives a nice shine and this draws the grain in the oak to a show piece. Try it on a piece of Oak first before doing the entire bed and see the results. I'm sure you will be pleased.
Back to the Marine Varnish, the under side of the bed where it was also done, remained beautifull where there was no sun. The 53 that I now have, has a Tonneau cover on it so the Sun doesen't bother it, but I still use the Min Wax paste wax on it.
Old Nov 27, 2005 | 03:09 PM
fking1's Avatar
fking1
I put the Marine Poly on my oak boards over 20 years ago and stored them until last year when I finally did my resto. Looks as good now as 20 ago.
Fred
Old Nov 27, 2005 | 07:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The original Johnson's Paste Wax is still around, it's nearly pure wax (carnauba) and looks good on any finished wood. Not meant for exterior use, but shouldn't hurt, just won't last I would guess.
