6.9 addicted to ether
Old Nov 23, 2005 | 09:10 PM
gbrett's Avatar
gbrett
Hi guys i have a 86 f 250 6.9 that has about 400k on it its completely wore out but i only use it occasionaly to go hunting anyway the glow plugs work and are all good I put them on a switch so I can turn them on or off when I want to I know ether is bad but its the only way it will start I am guessing there is no compression left anyway i wanted to know if anyone knows where I could get a either injection set up like they used to have on tractors just for the the convienence of not having to get out and spray it in
Old Nov 24, 2005 | 05:24 AM
bilder12's Avatar
bilder12
You could try a farm supply store. You may have to drill a small hole in the intake manifold.
Old Nov 24, 2005 | 09:06 AM
Hamberger's Avatar
Hamberger
Good luck. The good engine core is worth something as long as you haven't stuck a connecting rod thru the cylinderwall.
Old Nov 24, 2005 | 01:58 PM
Lazy K's Avatar
Lazy K
Try searching the web for your nearest Case tractor dealer. You should be able to get used units from Case tractors. The system consists of a can holder with a solenoid that when switched on fires the aerosol can into a tiny plastic pipe fed into the intake manifold.
Old Nov 25, 2005 | 11:24 PM
smiller4597's Avatar
smiller4597
If you are using ether DISCONNECT the glow plug relay!!! you wont need them if you are using ether anyway and ether and glow plugs dont mix well. If you spray ether right through the driver side of the grill into the air intake it works well, no need to open the hood and open the air cleaner.
Old Nov 26, 2005 | 07:09 PM
ozzy460's Avatar
ozzy460
make sure you disconnect the glow plugs if you use either. you can have a fire. also don't use too much either. you can either lock the motor(will turn over, but real hard) and this can bend a rod. or you can blow a head gasket. one little squirt . did this for over a year and never hurt the motor.
Old Nov 26, 2005 | 10:56 PM
mhannink's Avatar
mhannink
if you get the either setup i would stroke the motor(crank it dry) then while cranking add the either to prevent hydro lock basicaly the same way they start the old planes and some high hp motors
Old Dec 18, 2005 | 10:11 PM
Muleford5's Avatar
Muleford5
are your glowplugs 12 volt or six stock are six but you can use 12 volt that way you can hold them on for a longer time and they dont weaken as one burns out
Old Dec 19, 2005 | 05:53 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Muleford5, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Jmartenskoop
26
Nov 6, 2012 09:10 PM
GiS
Sep 22, 2005 09:54 AM
Nightrain
59
May 14, 2005 07:10 PM
Kirkus05
Aug 16, 2004 06:05 AM
muscletruck7379
Sep 16, 2003 02:06 AM
