need help , diff & trans 65 4x4
Old Nov 23, 2005 | 08:36 PM
mtpcage's Avatar
mtpcage
i have a 65 4x4 , trans should be a new process and dif dana 24. I have no shiff diagram to go by was playing with the diff make sure it works.
QUESTION . DIFF all the way forword is high , middle is neutral , back to the seat is low
TRANS, 1up , 2 down , 3up, 4down , reverse up, grannay low down.
know it a dum question makeing sure its right.
Old Nov 24, 2005 | 06:08 PM
mtpcage's Avatar
mtpcage
can someone help me out with the trans question? think it a t98 not sure what the granny gear is.
thanks happy turkey day
Old Nov 24, 2005 | 09:06 PM
66beater's Avatar
66beater
I answered your Trans question back in the 61-66 forum, but to add to it, that shift pattern doesn't sound like a Dana24. It may be a Dana21, a NP 203, or a NP 205. Normaly, the shifting should be:
2wd - 4wd high - neutral - 4wd low
If it shifts only in only 3 positions, then its either:
2wd - neutral - 4 wd. no low range
or:
4wd high - neutral - 4wd low. with an all time 4wd system.
it sounds like someone swapped a few things around on your truck. Post some picks of your setup in your gallery and someone should be able to identify what you have
Old Nov 26, 2005 | 04:03 PM
mtpcage's Avatar
mtpcage
PICS ARE IN MY GALLERIE UNDER, trans unknow
Old Nov 27, 2005 | 04:26 PM
oldhalftons's Avatar
oldhalftons
is the shift pattern?
2 4 R
3 5 1
If so thats a medium duty Clark 5 spd and 5th gear should be a mild overdrive.
That big drum in the back is your parking brake.
Old Nov 28, 2005 | 04:43 PM
mtpcage's Avatar
mtpcage
1 3 R
2 4 5
From the stop i can take off in the 5th so i think its a low gear not the OD model, don't have the nerve to shift to that gear going 50mph.
let me know
thanks
Old Nov 29, 2005 | 03:38 AM
Sam_Fear's Avatar
Sam_Fear
oldhalftons is right. If you can take off in 5th gear, it isn't really 5th gear then is it? Looking at your pics you definitly have the Clark 5 speed. Medium duty or Heavy duty I don't know, but it is a Clark. Overdrive is in what is normally consider 4th position. Start in 2nd gear for normal driving and use the gear below reverse (1st) for starting out when dragging a house or something.
Old Nov 29, 2005 | 03:03 PM
mtpcage's Avatar
mtpcage
thanks sam , it help. starting to redo the truck any idea on the bed 120 wb, if i try and put a short bed on.
