SAS Gear Ratio
Old Nov 28, 2005 | 05:19 PM
kellar's Avatar
kellar
SAS Gear Ratio
Is it posible to use a solid axle with 3.50 gears in the front of my 94 F-150 with a 8.8 and 3.55 gears? Will it be hard on the transfercase and 4x4 system?
Old Nov 28, 2005 | 05:22 PM
The SnoMan's Avatar
The SnoMan
It close enough that it will not be a problem. Want axle are you using in the front that has 3.50 gears in it???
Old Nov 28, 2005 | 06:14 PM
kellar's Avatar
kellar
I'm using a Dana 44 out of a 79 Bronco.
Old Nov 28, 2005 | 06:20 PM
chrono4's Avatar
chrono4
shouldnt be a problem, not enough to notice on dirt, but dont ever try runnin it on dry pavement, or pavement period.
Old Nov 29, 2005 | 03:59 PM
andym's Avatar
andym
You're just inside being OK. I would run it, but like chrono says, never on dry pavement. Not that you should ever run 4x4 on dry pavement...
