NP 203 conversion
Old Feb 20, 2002 | 06:47 PM
ford429cu's Avatar
ford429cu
NP 203 conversion
Old Feb 20, 2002 | 09:48 PM
thitdog's Avatar
thitdog
NP 203 conversion
My 77 f-150 has the full time np203. somewhere before i got it, someone had installed warn locking hubs on it. My question is how to tell if they did the transfer case conversion or not. Any help would be apreciated.
:-X11
Old Feb 21, 2002 | 01:30 AM
rick_369's Avatar
rick_369
NP 203 conversion
If you unlock your hubs, and the truck doesn't move, then they didn't do the T-case
Old Feb 21, 2002 | 11:58 AM
petem's Avatar
petem
NP 203 conversion
I believe one method would be to check the range selector. If a conversion kit was installed it should operate like a part-time unit (2H-2L-4H-4L). A sure-fire test is to jack up rearend, make sure hubs are not locked, put truck in drive and see if the differential in the t-case is working and spins the front driveshaft.
