Won't start....
Old Nov 23, 2005 | 02:39 PM
pricja00's Avatar
pricja00
Won't start....
85 f250 plow truck.... sat unused all summer... snow flakes fly tonight.
Can't get the damn thing started... it has a new carb, it's definitely getting fuel.... It's definitely getting spark. It cranks and fires right to the edge of repetitive combustion and then won't continue to fire. Losing my mind. Ran fine last season... Jasper motor has about 4k on it.... HELP!
Old Nov 23, 2005 | 02:52 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Nov 23, 2005 | 04:25 PM
Franklin2's Avatar
Franklin2
Pull some of the sparkplugs and see what they look like. If they are dry, I would make sure the choke is working, or pump the heck out of the gas pedal to try to make it run till it warms up.
If they are wet and smell like fuel, I would check the choke to make sure it's not sticking, and you possibly are going to have to buy some new sparkplugs. Sometimes when they get wet, they take a long time to dry out and they will not fire.
Old Nov 23, 2005 | 05:42 PM
o2outlaw93's Avatar
o2outlaw93
Try dumping some fresh gas down the carb. Might have bad gas if it sat all summer. Also since it sat for awhile especially if it was outside a critter might of chewed up some wiring seen this happen before. good luck , expecting 1 to 2 inches here tonight.
styleside96
1997 - 2003 F150
Nov 19, 2012 09:37 AM
Humam1953
Jan 1, 2007 10:13 PM
jf1082
1983 - 2012 Ranger & B-Series
23
Oct 3, 2004 08:59 PM
AggiePSD
Oct 26, 2003 09:43 AM
wolverineflight31
Aug 4, 2003 09:58 PM
