transmission over drive?
Old Jan 26, 2002 | 09:07 PM
MGT351's Avatar
MGT351
Old Feb 20, 2002 | 08:46 AM
fordlowboy's Avatar
fordlowboy
hi
I'm wanting to put a over drive transmission in my 78 4x4 behind the 460 and to the np205, is there a transmission to do that and what modifcation would i have to make?
thanks for your time!
Old Feb 20, 2002 | 11:19 AM
79f3504x4's Avatar
79f3504x4
Dont have a clue but would love to have one as well. I removed an Over/underdrive box from an old 1 ton chevy. It looked like a transfer case had shifter,etc. Brownlite Manufacturing built it.Was simple gearing inside to give you over&under drive. I was told these have been obsolete since the '60s. We couldnt find parts[we got lots of blank stares] and I have since lost track of the thing.But it was neat idea. Had u-joint input & output dont know how you could use on 4x4 unless it was a hiboy.
Old Feb 20, 2002 | 05:37 PM
Bruce in SC's Avatar
Bruce in SC
Check out this link from the tech articles - just posted this month.
https://www.ford-trucks.com/articles/feb2002/index.php
Bruce in South Carolina
1977 F-100 Ranger XLT
1984 Volvo 245 Turbo - it's a Ford now!
Old Feb 21, 2002 | 05:30 PM
Alwaysfixin's Avatar
Alwaysfixin
Another idea is to try the Gear Vendors over-underdrive behind the transfer case. This way you can use the original C-6 or if you want, the manual transmission. I think the cost is around $2,500. If I remember right the only major thing you have to do is shorten the rear driveline. It can only be used in two wheel drive since it bolts on to the back of the transfer case.
Old Feb 22, 2002 | 08:30 AM
fordlowboy's Avatar
fordlowboy
hi
I'm sorry, i might not have said it right, i mean a four speed transmission (automatic. I have found (over-under drives) for manual transmissions.
