'98 Navigator, 4WD problems
Old Nov 23, 2005 | 10:53 AM
ashardin's Avatar
ashardin
98 Navigator with 70K miles
Winter is almost here, and I've found a problem in my 4WD when I tried to use it this morning in the snow. <O
Admittedly, its been a while since I used it (not much need in the summer) and when did put it into 4WD I was having problems on tight turns (think parking lot tight). It seemed in my limited experience like the front differential was not working, as I was getting noise and a little hopping on the tightest turns. It seemed like both wheels were turning at the same speed and not allowing those tight turns.
Is this pretty common? I’ve got zero problems in 2WD and A4WD which would make sense if it was the front diff, since that axle would not be engaged. My next question is what type of $$$ am I looking at for this. If it’s a big time fix I’m going to deal with not having it for a while, but maybe it’s a simpler fix. Any input would be appreciated.
Old Nov 23, 2005 | 12:11 PM
scottspoerry's Avatar
scottspoerry
It's Supposed to be grabby
Have you ever really used it in 4hi before? My truck, and every other 4wd that I have owned feels weird when in real 4wd because the inside and outside wheels are now moving at the same speed...even though the inside wheel is not traveling as far as the outside wheel. The steering feels very grabby....it's a good signal that you ARE in 4 wheel drive. And it's the reason that you only use 4hi and 4lo in slippery or offroad conditions, and never on dry pavement. I think you are exactly correct..it's the side effect of a locking diffential.
Old Nov 23, 2005 | 11:19 PM
eric james's Avatar
eric james
What you are experiencing in 4 hi is normal. Both driveshafts are turning the same speed, locked together. You get wheel hop and steering jerk. Only use 4 hi/low on very slippery surfaces (mud or snow or boat ramp). Using 4 hi/low on non slippery surfaces will eventually cause more damage than you will like to pony up for.
A4WD pretty much does the job 95% of the time without any wheel hop or steering jerk because the driveshafts are allowed to turn at different speeds.
Old Nov 24, 2005 | 09:01 AM
ashardin's Avatar
ashardin
OK, thanks guys. My experience is with full time 4x4 vehicles, obviously the axles aren't locked on those. I didn't realize the Navigator was locked. Thanks for the input.
LGS
Sep 24, 2016 08:08 AM
serussell
Sep 4, 2016 08:58 AM
Surfcop
13
Apr 9, 2015 12:08 PM
BigGreen7.3swap
13
Sep 28, 2014 09:21 PM
PhilfromFlorida
Apr 2, 2008 03:50 PM
