1978 - 1996 Big Bronco
code 4 ?!?!?!?!?!?!
Old Nov 23, 2005 | 05:53 AM
motorcitybronco's Avatar
motorcitybronco
code 4 ?!?!?!?!?!?!
here is a new one. 94 bronco 302 e40d 4 wheel abs. after the thuck sits for a while (hot outside or cold outside) truck will idle high for a few seconds around 1500 rpmsthen it drops below 500 rpms shoots back up and the check engine light will flash 4 times. any ideas on what this is. i hooked up a matco determinator scanner and came back with a code 11 all good..
thanks
Old Nov 23, 2005 | 08:00 AM
muckypaws's Avatar
muckypaws
what happens after this? does it idle high all the time?
Maybe start checking the IAC controller on the throttle body - is it stuck open thus causing a high idle speed?
When you scanned it was the KOEO or KOER?
Old Nov 23, 2005 | 08:52 PM
motorcitybronco
it idles perfect after a min or so scanned both ways.
Old Nov 24, 2005 | 07:03 AM
muckypaws's Avatar
muckypaws
hmm wierd one! not sure what to suggest next... Might need input from Greystreak92 for this one.
Old Nov 24, 2005 | 10:00 AM
Black Ford XLT's Avatar
Black Ford XLT
Have seen many a posts about throttle bodies being dirty. Not that this is your problem but an area to look at TR
Old Nov 24, 2005 | 10:45 AM
tigerhawk_212's Avatar
tigerhawk_212
You may want to check your iac and tps with a multimeter and/or check something else you think may be causing this.
Old Nov 25, 2005 | 09:20 PM
autx790's Avatar
autx790
This may not be what you mean, but when you first turn the engine on I get a 4 as well, which i was told means it found a V8 engine, 3 for V6 etc. then it will rev the engine a minute or so then start out putting your codes.
Old Nov 26, 2005 | 05:03 PM
ctch88's Avatar
ctch88
autx790 is correct, the first flashes during your KOEO test is your engine identification code. four flashes means you have a V8
Old Nov 27, 2005 | 11:23 PM
greystreak92's Avatar
greystreak92
It also means that somehow the EEC computer believes that it is being put through the KOEO test every time you start it. Thats a problem. I'd check the test connector and the wiring harness to it. The KOEO test can be administered by simply jumping the correct pair of terminals in the EEC test connector together. It may be that somehow these two terminals or the wires to them have shorted. Otherwise I am unaware of any reason why the light would flash at all during normal operation in other words without the EEC test terminals jumped together).
bullrider2139
2004 - 2008 F150
Nov 29, 2012 03:16 PM
LONEPINERON
Mar 19, 2006 07:35 PM
Jrock909
Jan 18, 2005 08:50 AM
codyW
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 18, 2004 12:41 PM
