Sponsored by: Real Truck
having trouble with ignition
Old Nov 22, 2005 | 10:41 PM
bigstroker99's Avatar
bigstroker99
I have a 1999 Ford F-350 7.3l diesel and got home shut her off and jumped back in her to go to town again and everything works but when you put the ignition in start position it doesn't do anything the relay clicks but thats it any ideas what could be wrong
Old Nov 23, 2005 | 05:34 AM
FortyFords's Avatar
FortyFords
Sounds like battery or connections to the batteries or starter.
Rich
Old Nov 23, 2005 | 06:23 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Nov 23, 2005 | 07:44 AM
FortyFords's Avatar
FortyFords
Enjoy FTE....and
yup theres that guy again!!!!!!
Old Nov 23, 2005 | 07:46 AM
bigstroker99
There is power down to the solenoid but the wire that runs from the ignition has no power
Old Nov 23, 2005 | 08:01 AM
FortyFords's Avatar
FortyFords
You have chk all fuses ?
Have you chk the ignition sw ?
also wiggle the gear shift lever on the colum if this is a auto (the dtr sw on the tranny could be loose or bad)The switch needs to be in park or neutral to start.
switch on the clutch pedal if a manual.
Rich
Old Nov 23, 2005 | 08:15 AM
bigstroker99
Have checked all the fuses and relays and they were all good I might try the Ignition switch but everyhting works but start so maybe i will check all the fusible links its an auto and maybe the nuetral safety switch too?
Old Nov 23, 2005 | 09:08 AM
BerkshireCoverit's Avatar
BerkshireCoverit
Had the same problem with my 2001 SD 7.3 three times, it was the starter gone bad each time. same way, everything was fine ,turn truck off go to restart nothing Each starter it was the same thing starter fried. Was told by another tech (not ford) the ford starters in the 7.3 aren't heavy duty enough to turn the 7.3s and they burn out, also told me they can be customized to handle the job but i really can remember how , something to do i think with changing the contact sizes for the wireing hookups. Anyway mine always seem to blow 1 month after the 1 year ford warranty. Good Luck
Old Nov 24, 2005 | 10:21 AM
bigstroker99
Hey thanks for all the suggestions it was the solenoid piece on the fender. Replaced it and the truck fired right up
copenhagenkid00
Apr 19, 2013 12:23 AM
FordTrucksKickGM
Dec 15, 2008 03:45 PM
Webslinger
26
Sep 17, 2007 06:09 PM
fordman777
Sep 25, 2003 05:36 PM
