Recalls
Old Nov 22, 2005 | 09:21 PM
savagefan's Avatar
savagefan
Recalls
Hello, does anyone know if Ford has a site to check for recalls on your vehicle? I ask because my 91 aerostar went up in flames due to a bad ignition switch that was under a recall that I was unaware of. Thanx.
Old Nov 22, 2005 | 11:16 PM
Jharger's Avatar
Jharger
Try Ford.com. Recalls have to be posted somehow from a leagal basis. In the least, a call to your local dealer.
TSB's however, are not required to be publicly available by the OEM. There are a few subscribed to service available for this information.
Old Nov 23, 2005 | 02:42 PM
jporter's Avatar
jporter
Recalls and TSBs are available on the NTSB's website. It is easily searched and is worthwhile to explore.
Ford has a website devoted to Ford Owners. Free registration. Should have a link from Fordvehicles.com. There is a spot to check for open recalls for your vehicle's VIN.
Old Nov 29, 2005 | 03:45 PM
edward r's Avatar
edward r
The best direct link I have found for recall is :
www.ownerconnection.com
(1) just click on the sideways arrow to the right of "Recall Information"
(2) then click on the brand you have beneath the "Check your vehilce Status" banner (ie: Ford Lincoln Mercury etc etc)
(3) just type your VIN in the blank box then hit the sideways arrow to the right of the blank box and any recalls particuar to your vehicle will come up!
Old Nov 29, 2005 | 06:54 PM
kregars's Avatar
kregars
You know..I was curious about this site as it stated there were no recall campaigns active, expired, or completed for my 94..so I called Ford..come to find, their online DB no longer supports 'legacy' models past 1997 to include their recall per the rep I talked too. Anyone able to confirm this.
NTSB shows all the recall and TSB's for the vehicle...I know that ford dealers can run the list (pulled and there is 1 outstanding recall issue that they are going to be doing tomorrow).
