Power Window Switch Light
Old Nov 22, 2005 | 06:48 AM
Beefford's Avatar
Beefford
Anyone have the little green light on their power window switch go out?? Just noticed one of mine out today.
Old Nov 22, 2005 | 08:16 AM
JIMY's Avatar
JIMY
Not sure if this is the issue, but if you lock the Windows, the lights on the rear (Crew Cab) go out. Unlock the windows and they go on.
Old Nov 22, 2005 | 11:30 AM
gpeade's Avatar
gpeade
the passenger front door goes out as well on my screw.
Old Nov 22, 2005 | 12:08 PM
Beefford's Avatar
Beefford
Nope, just the drivers side "up" light on the drivers door. Annoying problem but not that big of a deal I guess.
Old Nov 22, 2005 | 01:00 PM
ATCS2004's Avatar
ATCS2004
I am having the same problem with mine. I can tap on the switch and they will eventually come on. Not a big deal, but I will probably have the dealer fix while I'm still under warranty.
The passenger switch lights do not illuminate with the window lock switch in "lock". I kind of like this feature.
Old Nov 22, 2005 | 10:24 PM
Neil's Avatar
Neil
Just had my switch replaced a few weeks ago for the same problem. Sometimes the little light would work, sometimes it wouldn't.
Old Nov 22, 2005 | 10:41 PM
ATCS2004's Avatar
ATCS2004
When they replace your switch, did they screw anything up? I have this fear that things just won't fit right or they will scratch something during the process..
Old Nov 22, 2005 | 10:45 PM
Neil's Avatar
Neil
It was a real simple repair. Took them about 5 minutes. The switch panel pops off, they unplug the harness, removed the switch from the cover, pushed the new one into place, plugged the wires back in & snapped the cover back into place.
No sweat!
Old Nov 23, 2005 | 10:12 AM
drifter397's Avatar
drifter397
Same thing here. 2004 screw. Just the drivers one is out. I was afraid to have it fixed out of fear it would not look as good as new after the fix.
Old Nov 24, 2005 | 11:07 AM
Dazz's Avatar
Dazz
Not trying to rub salt into wounds, but on my '04 RCab all the lights on all the door switches remain on. I only looked at it once at night with the windows in up position.
Old Dec 2, 2005 | 12:23 AM
dboxman7's Avatar
dboxman7
Nice to know I'm not the only one. Other than a shimmy in the front at highway speed, the only problem I've had...other than disappointment with stock 18" tires.
Old Dec 2, 2005 | 12:52 AM
nwiggan's Avatar
nwiggan
That is how they are supposed to work! Like when you put in a cd at night only those function lights up. Pop out the cd all the radio button lights up, the wonders of the solid state pcb. (Printed circuit boards)
Old Dec 2, 2005 | 08:52 AM
tshannahan's Avatar
tshannahan
i have had the same problem but only on my driverside power window switch. every now and then the light goes out but if i play around with the switch it will eventually come back on. this happens regardless is the windows are locked or not.
Old Dec 2, 2005 | 10:00 AM
KevinM's Avatar
KevinM
No problem with mine, my switch lights on all 4 doors of my SCREW Lariat are always on!
Old Dec 2, 2005 | 11:16 PM
kamperco's Avatar
kamperco
1987 460 class c motorhome
<HR style="COLOR: #666666" SIZE=1>Did you ever solve the stalling problems on your motorhome? I have the same year and engine and it is doing exactly what you described. Ford has been no help. I could use help fast because I am to use the motorhome for christmas 2005. Thanks
Fred
