thermostat
Old Nov 21, 2005 | 11:20 PM
ALASKAF250's Avatar
ALASKAF250
thermostat
After my truck in 10+ or below with out being plugged in. The truck will not heat up. Once it over heated. I am thinking is the thermo is sticking in the close position. Anyone out there hear of this or have this happen?
Old Nov 26, 2005 | 07:38 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...bump...let's see if we can find anyone else with this problem
Old Nov 26, 2005 | 04:05 PM
ALASKAF250's Avatar
ALASKAF250
Ya it's wierd. Plugging in now and all is well.
Old Nov 26, 2005 | 04:09 PM
Bob Ayers's Avatar
Bob Ayers
I would say your thermostat is sticking open, not closed.
Old Nov 27, 2005 | 08:32 PM
ALASKAF250's Avatar
ALASKAF250
OK the truck cab blows cold air and the motor gets really hot. Happened today and I had to leave her. After being plugged in for aprox 6hrs she was normal/. I might drain fluid and swap out stat?
Old Nov 27, 2005 | 10:11 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Seems like a good place to start. Would also pressure test system and cap.
Good luck, but it sounds like your doing (or will do) the right thing to check out the problem.
Old Nov 28, 2005 | 09:31 AM
ALASKAF250's Avatar
ALASKAF250
Ya the dealer up here had the rig ovcernight an couldnt repeat the prob. So they wouldn't do the swap under warrenty. Plug in ladt night befor bed. -4f this morning we'll see what happens.
Old Nov 28, 2005 | 07:40 PM
wesran's Avatar
wesran
Sounds like something plugging the heater hose and no warm water circulating through the heater core.
wesran
Old Dec 6, 2005 | 06:42 AM
Maxium4x4's Avatar
Maxium4x4
Did you ever solve your problem Alaska? Today my truck put out luke warm air and cold at idle. Diagnostics show an engine temperature of 171 degrees.....guess I'll be doing my thermostat today. I din't find a quick search on operating temps for the 6.0L.....but dang it's cold out 7 degrees this morning..
Old Dec 6, 2005 | 11:53 AM
ALASKAF250's Avatar
ALASKAF250
I just started plugging in over night and that seems to do the trick.
