broken steering bracket
Old Nov 21, 2005 | 11:12 PM
66f14evr's Avatar
66f14evr
On my 89 F250 4x4,when I push the clutch pedal down the sterring column moves to the left.I looked for any loose bolts and found none.So I took the instrument cluster out and found 2 metal bars that broke off from the top of the column.They look to be steel and the upper column bracket is aluminun or some sort of cast.How does this get repaired.
