Sluggish
Old Feb 24, 2002 | 06:21 PM
blaxuede's Avatar
blaxuede
Sluggish
K, my truck's been sitting for a while. I pulled the tranny and rebuilt it (NP435)And put in a new clutch. Got everything back together and started it up. Runs o.k. when warm, but i gotta hook up the choke and everything like that etc. But when I go to drive it forward in 2nd gear it seems really sluggish under load and I gotta keep the revs high or else the engine will stall. 1st gear is fine, and reverse works well. But I know that my coil isn't good, it's an old one i found around the shop and my points aren't in that great of shape either. Now would a faulty coil and points cause the engine to be sluggish? I think it would, so i'm gonna get an MSD blaster 2 coil and a good set of points and see how it works out. If you got any suggestions, throw them at me.
Old Feb 24, 2002 | 08:04 PM
79f3504x4's Avatar
79f3504x4
Sluggish
Choke may be staying shut if its not hooked up. Lose the points & go with electronic-even stock Duraspark is light years better than old worn points dist.
Old Feb 25, 2002 | 08:00 PM
birdog79F150's Avatar
birdog79F150
Sluggish
Check your vacume advance if it isnt working or the vacume line is leaking this too will cause it to be sluggish. hope this helps let us know.
Six strings and Ford trucks music to my ears.
Old Feb 25, 2002 | 10:26 PM
Blue_oval_driver's Avatar
Blue_oval_driver
Sluggish
If you have parts that aren't hooked up, and parts that you know are faulty..... I'd start there. Fix what ya know aint right first! It'll be a lot easier to find the problem. Just my .02 worth.
Brian
1970 F250 2wd (Nice & 4-sale)
1972 F350 Flatbed
1976 F250 4wd (Huntin rig)
1999 F350 4wd (work truck)
Old Feb 25, 2002 | 10:33 PM
Blue_oval_driver
Sluggish
