Don't know how many of you around here watch Mythbusters, but I saw one last week where they busted the myth that running with your tailgate down increases your gas mileage.
This actually really suprised me since I had always heard it would help, so I decided to post it here for anyone who missed the show.
They had two identical f-150 supercrews, 04 or up I couldn't tell which. They started each with the exact same amount of gas, loaded with the exact same weight, A/C set at the same level and tried to be as simiair as possible. All acceleration had to be done with the cruise control and they had to obey all speed limit signs. They drove out into the desert so I imagine it was mostly highway speeds, and just kept driving until they ran out of gas. Jamie drove with the tailgate down and Adam drove with it up. When it was all done Adam got about 30 miles further than Jamie, so there was about a 1mpg decrease by having the tailgate down.
After that they double checked the results by placing a model in a water table and observing the flow of water. With the tailgate up there is a swirling motion of the air created in the bed and the rest of the air goes over the bed and behind the truck. When the tailgate is down the air comes down into the bed and drags across the rear of the truck. I would have like to see a test to see how a tonnuea cover or topper effects the mileage as well.
In a test I had seen a couple of years ago, they reported the same - a slight improvement with the tailgate UP. A tonneau improved mileage further, even a half covered bed was an improvement. (They also had analysis of the air turbulence, pressure drops, etc.) Of course I know people who SWEAR that they get 2-4 MPG more with the tailgate down...
Pickups aren't exactly R&T's cuppa tea, but certainly a lot of people own them. Each year, the Ford F Series and Chevrolet Silverado vie for the title of best-selling vehicle in the U.S. Hence I see the following as a public service, as well as a neat technical tidbit.
Investigators at the National Research Council of Canada have determined that pickup truck aerodynamics is generally degraded — not improved — by the often-seen practice of lowering or removing the tailgate. Drag is generally greater and, to the detriment of yaw stability, rear lift can be increased by as much as 60 percent. Popular mesh tailgates worsen aerodynamics of these vehicles as well.
The researchers measured drag, lift and yaw behavior of pickup trucks in the same wind tunnel where, years ago, we evaluated Champ-car aerodynamics ("Putting the CART Before the Wind," June 1984). They also performed Computational Flow Dynamics analyses of two simplified pickup shapes. These CFD results agreed with their tunnel findings.
The differences in C<SUB>D</SUB> were measurable, though not profound. For instance, with a 2002 Ford F-150 Crewcab, its tailgate-up C<SUB>D</SUB> was measured at 0.5304. Tailgate down, it was 0.5425; tailgate off, 0.5596.
Indeed, there was one case, a 2001 Ford F-150 standard cab, where lowering the tailgate actually improved C<SUB>D</SUB>, albeit insignificantly, from 0.5230 to 0.5215. (And, yes, pickup trucks are bricks aerodynamically.)
In their report (SAE Paper No. 2004-01-1146), the researchers discussed underlying reasons for the phenomena. In general, there's a wake immediately behind any pickup cab, and this suction is greater without a tailgate in place. True, presence of a tailgate adds a small drag increment; but the cab wake predominates.
A partial tonneau cover helped, lowering the extended-cab F-150's 0.5304 to 0.5072. A full tonneau cover was better, dropping the standard-cab F-150's 0.5230 to 0.4967.
From what I hear, the tailgate left down causes lift in the rear and thus increasing drag. Hence, more fuel consumption. Now, the question is what if the tailgate is removed? Will that help?
