remove scratches from windshield?
Old Nov 21, 2005 | 12:06 PM
Brian_B's Avatar
Brian_B
I don't know if this is in the correct forum or not. I recently purchased a 56 f-100 that has several scratches in the windshiled from the wipers being bad (at some point). I doubt that anything will repair it, but is there some sort of polish or process that I can do to make them less noticible?
Replacing the glass is a future option, but expensive.
Thanks,
Brian
Old Nov 22, 2005 | 07:15 PM
otpracer100's Avatar
otpracer100
Hey Brian,i install autoglass for a living.If the scratches are deep enough to feel with your finger nail the there is nothing you can do. There is a polish for this but you would probably distort the glass before the scratches disappear.
Old Nov 22, 2005 | 08:08 PM
Brian_B's Avatar
Brian_B
Ahh.....ok. I figured I would have to live with them until I get a new windshield. Thanks for the information. Its nice to have pros around to ask these thing.
Old Nov 29, 2005 | 06:03 PM
Gervis's Avatar
Gervis
you can use scratch removers but most do not work..or you need to use a plastic polish formulated to cure this problem. A good polish will not only remove scratches and imperfections but will also leave a protective film behind. By using these polishes you also bring back the optical clarity of the windshield eliminating distortion and glare.
Old Nov 30, 2005 | 06:39 PM
otpracer100
Just curious as to what these polishes may be called?
Old Dec 3, 2005 | 07:56 AM
NorthPac's Avatar
NorthPac
Cerium Oxide and a glass polishing pad, you can make deep scratches, chips less visible.
http://www.deltakits.com/dki-catalog/co1.html
Old Dec 3, 2005 | 11:36 AM
Bigdawgkp's Avatar
Bigdawgkp
Hey otpracer100! Do you know of anything that will remove water spots from autoglass?
Thanks-bigdawgkp
Old Dec 3, 2005 | 03:11 PM
otpracer100
Cerium oxide is exactly the stuff i was talking about.Once again I will say that if you polish too much in one spot it will distort the glass.It will also give it a nice rainbow effect.Hey Bigdawgkp,you can try a solution of vinegar and water and use some old newspapers.If it's really bad like acid rain spots you can use a mirofinishing rubbing compound on it.Just don't buff too long in one place as it could create a halo effect.
Brian Skinner
Aerostar
13
Dec 28, 2021 11:21 AM
plgebbia
Mar 30, 2011 01:00 AM
Truxx1956
46
Jun 21, 2008 12:27 AM
Brian_B
Jul 19, 2007 09:21 PM
bcwaack
Car/truck Buying Advice
Jun 15, 2002 01:21 AM
