engine vibration
Old Nov 20, 2005 | 11:00 PM
hoamskilet's Avatar
hoamskilet
engine vibration
I've got a 98 expy with the 5.4. About 1-2 months ago it started up out of the blue. When I start the truck up, there's a pretty bad vibration you can feel. It seems like the lower the RPM's/load, the worse the vibration is. Also, as the engine warms up it smooths out. After driving for a few minutes and it gets good and warmed up, the vibration pretty much goes away and things feel normal. Any ideas? Initial thoughts were fuel injectors, but I'm thinkin if that was the case, the vibrating would continue even as the engine warms up. Any help/advice would be appreciated.
Old Nov 23, 2005 | 05:17 AM
FortyFords's Avatar
FortyFords
No chk engine lights? does the bulb work on the dash when you turn the key on?
A dirty Iac or maf.You could laso have a slight vacum leak somewhere untill it warms up.
A cop that is going bad or sparkplug boot that is burned up or cracked could cause a problem like this also.Have you changed plugs lately?
Rich
rlreed
1997 - 2003 F150
Mar 10, 2011 02:56 PM
09 Razor
2009 - 2014 F150
Jan 18, 2010 09:37 PM
CommanderCarry
2004 - 2008 F150
Apr 11, 2009 09:02 PM
901
24
Jun 15, 2008 04:55 PM
