72 E-300 MotorHome
Old Nov 20, 2005 | 08:10 PM
rls302s's Avatar
rls302s
Cool 72 E-300 MotorHome
Hi Everyone
Well got the tranny service finished but I got a little problem, as I was removing the filter screen something fell out into the drain pan. Well when
I cleaned it out I found a little spring about 1 & 1/2 inches long along with a little round piece of metal with a little tit on one end and it was sort of
concave on the other, like maybe a ball bearing might go in there, and the
tit end looks like it goes on the spring. Now Where did this come from???
The Valve Body??? Does anyone have any Idea. When I drained the converter the fluid was black, not dirty brown like the pan fluid, so guess
it had probably never been drained before, Well it still does that little slip
thing if I get on it just a little but quits & acts normal as soon as I let off the gas. So I hope I'm just looking at another Valve Body & not a Tranny swap. Maybe $250.00 wasn't so cheap after all, but I guess the Engine is
worth that much. It runs good just have to pump the heck out of it to get to start when it's cold.
Ron
Old Nov 20, 2005 | 09:34 PM
cheez67's Avatar
cheez67
Lightbulb
i can not say for sure if this is what you found but some trannies had a spring that attached to the filter to hold it in place, in went against the pan and put pressure onto the filter. hope this helps.
Old Nov 21, 2005 | 08:54 PM
rls302s's Avatar
rls302s
Question C-4 Parts:
Cheez67
Thanks loads I'm going to stop by Fisher Transmission tomorrow & talk to one of the rebuilders and see if thats what it is. I didn't see how parts could be comming out of the Valve Body & the trans still work.
Ron
Old Nov 22, 2005 | 09:14 AM
rebocardo's Avatar
rebocardo
Ask in the tranny forum, it might just be a part they use during the assembly line process and is meant to be thrown away.
vasten
1997 - 2003 F150
Sep 28, 2010 09:13 PM
64F-100
Aug 24, 2010 06:58 AM
Izzy351
43
Sep 11, 2009 08:06 PM
jgrady
Nov 11, 2005 02:26 PM
