Changing Motors
Old Nov 20, 2005 | 08:03 PM
welderman1's Avatar
welderman1
Changing Motors
Hello,
I have a 84 F150 4wd, standard tranny with a 300 inline in it, it is giving me some problems and i am thinking about swapping the motor out for a 302 which i would like to have more HP anyway,
I was wondering if i do this will i have to change a lot of things as far as motor mounts, bell housing, and so on.
thanks for any help,
welderman1
Old Nov 20, 2005 | 09:18 PM
Franklin2's Avatar
Franklin2
You will have to grind the motor mount frame perches off and install v8 ones.
Old Nov 21, 2005 | 09:37 AM
fordborn's Avatar
fordborn
Thread moved to "Engine Swaps" forum. Should find more responses to the question here.
Old Nov 21, 2005 | 09:42 AM
Kemicalburns's Avatar
Kemicalburns
the front motor stands will need to be moved. i would suggest going to a 5.8 though instead of the 302. its the same amount of work and the 5.8 is a far better truck motor. the 300-6 will out perform a 302 in a truck application just so you know. i would either stay with the 300 or go 351w. its a good swap ask away if you have more questions.
later
