Running board light replacement..
Old Nov 20, 2005 | 06:53 PM
Spooner's Avatar
Spooner
I must be retarded because I am not seeing how to get to the bulbs in the running boards...I have searched the site but haven't found anything..help!!
-Nick
Old Nov 20, 2005 | 07:00 PM
Big Rig's Avatar
Big Rig
Spooner,
It's easy..You have to unbolt the metal cover plate below the light socket area. You move the metal cover to the side and rotate the light bulb socket and assy and pull the whole assy out of the hole and change the light bulb.
Big Rig
If the connections are rusty, I also spray some WD 40 on it to clean them out..
Old Nov 20, 2005 | 07:01 PM
Spooner's Avatar
Spooner
Is this under the running board or behind it??
Old Nov 21, 2005 | 12:49 AM
RACERX7775's Avatar
RACERX7775
anyone know what bulb ####. do they make brighter ones???
