2000 Ranger Torque Converter
Old Nov 20, 2005 | 02:28 PM
joe1mo2's Avatar
joe1mo2
Can Anyone Tell Me If The Torque Converter Lock Up Switch Can Cause Shifting Problems And Also Feels Like The Truck Has No Power At Times? Only Does It After Driving Several Miles. Turning It Off For A Few Mintutes Makes It Worse. Anyone Else Have This Problem? How Hard Is It To Replace?
Old Nov 20, 2005 | 04:28 PM
Ken00's Avatar
Ken00
The most common causes of shifting problems is a bad VSS or a leaky valve body. Are you having any other problems?
Old Nov 20, 2005 | 04:56 PM
RangerPilot's Avatar
RangerPilot
Shifting problems lead me to agree with Ken and the VSS (Vehicle Speed Sensor) having some problems.
Does the vehicle idle ok? Can you rev it in neutral/park without problems?
Vacuum perhaps?
Old Nov 21, 2005 | 04:13 PM
joe1mo2's Avatar
joe1mo2
Yes. The truck acts like it goes into nuetral when going into third then it slams in. Also if I let it set for a few minutes after it starts doing this, when I begin to drive again its slow about down shifting back to first. I can manually shift it fine though.
Old Nov 21, 2005 | 04:14 PM
joe1mo2's Avatar
joe1mo2
No problems with idle and it revs up fine.
Old Nov 21, 2005 | 08:34 PM
Ken00's Avatar
Ken00
I know I have read about a TSB on a leaky valve body but I can't find a copy, this might cause the problem.
Anyone have the TSB number??
Old Nov 22, 2005 | 02:40 PM
Ponyracer's Avatar
Ponyracer
no but if he takes it for a short drive in manual first gear up to 25 MPH and lets off of the throttle and the truck freewheels and doesnt try to slow down with engine braking then the valve body gasket is blown out.
