Sponsored by: Real Truck
Lift questions
Old Nov 20, 2005 | 02:17 PM
forced5's Avatar
forced5
Lift questions
I currently have a 2004 F250 SD/SC SB...5.4L, 4x4,ect... I am looking to raise the truck just a little bit more than now... I figured I would put the F350 rear block in it, but what all would I need to do the front??
Old Nov 21, 2005 | 08:20 PM
forced5's Avatar
forced5
knowone has lifted their truck on here??
Old Nov 22, 2005 | 06:58 AM
2003V10F250's Avatar
2003V10F250
2 or 4 inch front hanger kit would be your least expensive mod to the front to raise it up with the rear.
Old Nov 22, 2005 | 07:07 AM
forced5's Avatar
forced5
Which would I want to use with the 4" F350 blocks?? Would I need anything else to do the install??About how much $ is the hangar Kit and where should I look... I am not that knowledgeable about lifts and am learning.. So, Sorry for all the questions and thanks for answering..
Brian
Old Nov 22, 2005 | 07:17 AM
2003V10F250
I personally have not installed or purchased a hanger kit. However it should be straight forward to do. As far as where to get one and how much they would cost you can shop around for what you want. I know alot of the folks on the board swear by Donahue Racing for their ride quality and performance. But I think there are other manufactures that offer the same kind of hanger kit. If you have the standard 250 config than add the rear block from a 350 (only 2" taller on the factory block) you can raise the front 2" and be back at the factory stance or go 4" up front for a more level looking rig. It all depends on what you want the stance of the truck to look like.
Old Nov 23, 2005 | 02:43 PM
kingz489's Avatar
kingz489
I have a six inch life from Donahoe Racing and the ride quality is great. High quality parts and I got if from Superdutyheadquarters. Great guys there.
Old Nov 23, 2005 | 08:25 PM
mattd17's Avatar
mattd17
www.nixonperformance.com sells hangar kits, and they custom build them to whatever size you want. not too expensive either....
Old Dec 2, 2005 | 05:44 PM
forced5's Avatar
forced5
WHere is a good place to get F-350 blocks?? I called Donahoe and they said their mini spring pack would get me level... Does this sound right??
Old Dec 3, 2005 | 09:48 AM
forced5's Avatar
forced5
OH yeah, DO I have to take the helper springs off the truck to install the F-350 blocks??
Old Dec 3, 2005 | 01:47 PM
02superstroker's Avatar
02superstroker
No.. you can continue to use the helper springs, your rear end will remain just how it is, only about 2" higher. I"m not sure if your current u-bolts are long enough for the new blocks, but either way it would be safer to go ahead and replace them when you put your new block in the back.
As far as the front goes.. Your best bet would be to go with a 2.5" or 3" hanger available from most major lift companies. RCD, Superlift have 2.5 inch, nixon can make you whatever, i think fabtech's is 3", etc. Here is a link to rocky mountain suspensions for your truck. I have used them in the past and have been very pleased. Super Duty Lifts The nice thing about the hanger lifts is that there is no change to the spring pack so you keep your factory ride. If you do the front 3" you will need new shocks, and by upgrading to a high quality shock like bilstein you will see a big ride improvement from stock. Superlift now gives you the option of bilsteins with their lifts.
Old Dec 3, 2005 | 07:50 PM
forced5's Avatar
forced5
No doubt I will definitely change the U-bolts if I do it... According to DOnahoe racing, The mini spring pack will not change the ride that much an should sit pretty much level with the spring pack and the F-350 blocks.. Does anyone have any other experiences with this that says otherwise... I would like to do a hanger kit, but money is a bit of an issue as I am trying to finish up my car...
Besides, If I would want to go higher in the future couldn't I just then do a hanger kit??
Old Dec 3, 2005 | 10:58 PM
02superstroker
Just remember they are trying to sell you a product.
I think that either way you go you will be happy and get the desired results.
There really isn't a wrong choice here.
Old Dec 4, 2005 | 07:21 AM
forced5's Avatar
forced5
I hear ya there.. It just seems that pretty much everyone on here directs others to Dodnahoe...
Old Dec 4, 2005 | 01:23 PM
02superstroker
It would seem that way wouldn't it.
Personally I think donahoe (edge) systems are overpriced for the superduty. I think that superlift offers a very comparable product, especially when purchased with the bilsteins for a much better price. Do a search on here if you are interested and you can find many threads about this very subject from years ago.
Old Dec 4, 2005 | 03:45 PM
4mil's Avatar
4mil
Just a note here, some guys have had clunking noises after trying the mini spring pack lift. I have seen the 4 1/2" hanger lift from donahoe installed and have installed the smaller one. Very strong and solid product.
