Oil & Lubrication
Chevron Supreme Question?
Old Nov 20, 2005 | 03:42 AM
Ed's Avatar
Ed
There was a time around '99, 2000, 2001 where wholesale clubs, SAM's Club and COSTCO were selling Chevron Supreme 5w30, 10w30 and 10w40 in 4 quart (1 GAL.) bulk containers. Very similar as to the blue plastic 1 gallon containers you can still find Chevron Delo 400 diesel oil (15w40) in. Has the 4 quart (1 gal.) containers been discontinued for Chevron Supreme Oil? Or does anyone know of a place that still sells the Chevron Supreme blue gallon jugs? Ed
Old Nov 20, 2005 | 09:10 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Probably only from a distributor, Ed.
Wish my Costco would carry the 5w30!
Old Nov 20, 2005 | 10:10 PM
ford390gashog's Avatar
ford390gashog
ed they stopped because no one needs just 4 quarts. anyways kragen has it on sale for .49 a quart. i buy about 5 cases when they do.
Old Nov 21, 2005 | 01:43 AM
Ed's Avatar
Ed
Wink
I more or less thought the same thing. However, on the other hand, Delo 400 is available in the 4 qt. (gal.) containers, but diesel engines require more oil per oil changes, in which a 5 quart or more jug would seem appropriate. Oh well, I'm sure there is a reason why. I too, have bought the Chevron 5w30 case sale @ Kragen. That has to be the best deal out there, for a quality dino oil. Horsepuller, I hope Costco does not discontinue carrying Chevron by the case. If you don't see it in SoCal, could the NoCal Costco's be far behind?! I hope not. Ed
PS I've used (and still have it in there) Chevron's ATF fluid in my Aerostar's A4LD auto 4 speed trans, with excellent results. Never a problem with the Chevron ATF Dexron III formula. In fact, Saturday afternoon while running some errands with the wife, I thought to myself how lucky I was not to have had any issues with the Aerostar trans. At 65 - 70 mph, on the freeway, the trans shifts up into OD, freeway cruising is quiet, and easy. I change the Chevron ATF once every three years whether it needs it or not, along with a new filter screen. The fluid still looks good, even with the hot Sacramento summers... Chevron ATF =
Old Nov 21, 2005 | 02:24 AM
ford390gashog
ed most diesel engines measure oil capacity by the gallon thats why it is sold by the gallon. some bog OTR engines are using 30 gallons in the sump.
Old Nov 21, 2005 | 07:33 AM
jschira's Avatar
jschira
I guess no one told Int'l. The 7.3 takes 15 qts. A little less in the 6.0.
Well, you did say most.
Old Nov 21, 2005 | 11:38 PM
Ed's Avatar
Ed
Ford390, so is it what you are saying that when a diesel is at the "add" mark on the dipstick, then it is actually 4 quarts low, or a gallon low? I'm assuming you're talking about big rigs (18 wheeler) diesel engines? If I am wrong, please correct me. Thanks! Ed
Old Nov 22, 2005 | 12:49 AM
ford390gashog
don't know about that. but cat mearsures sump capacity by gallons not quarts, so does detroit diesel most OTR trucks list the oil cpacity in gallons. not quarts like they do for cars.
Old Nov 22, 2005 | 10:30 AM
Big O Dave's Avatar
Big O Dave
Thumbs up
That was my impression, too... the large, OTR diesels have sumps measured in gallons, not quarts. The small diesels in heavy duty pickups have sumps measured in quarts.
Old Nov 30, 2005 | 11:34 PM
boulderdentist's Avatar
boulderdentist
Costco and viscosity
My Costco carries Chevron only in the 10W40 and also Delo. I cannot understand why they waste shelf space on 10W40 when most vehicles call for 10W30, 5W-30, or Xw-20-30?
Old Dec 1, 2005 | 09:39 AM
jimandmandy's Avatar
jimandmandy
Obsolete 10W-40 is still a big seller. Many a typical DIY oil changer, who maybe frist started driving a 1970's car that spec'd it, is very old school, "thicker is better".
Jim
agpopp
Modular V10 (6.8l)
Jan 15, 2017 11:24 AM
Ed
Oil & Lubrication
Dec 4, 2004 02:12 PM
ford390gashog
Oil & Lubrication
17
Dec 2, 2004 11:53 AM
Little Bro
Oil & Lubrication
Sep 18, 2004 10:33 AM
BrianA
Oil & Lubrication
Mar 22, 2003 09:03 PM
