2150 carb, "extra hole" question+
Old Nov 20, 2005 | 12:27 AM
Dave Carney's Avatar
Dave Carney
When I was rebuilding this carb tonight I noticed an extra, threaded hole, just up and to the right of the right hand (looking at the front of the carb) idle mixture screw. I didn't take anything out of this hole, what's it for and shouldn't it have something in it? Application is a '82 F100, 302.
Old Nov 20, 2005 | 09:22 AM
Dave Carney
So, I'm pondering this extra hole and now I'm wandering if maybe somebody put that there because they were unable to tune it enough with just the 2 mixture screws, due to all the the problems this truck had....I can't figure what else it would before, I'm taping over it until I get an answer from one of you guys in the know
Old Nov 21, 2005 | 09:16 AM
rfxj3's Avatar
rfxj3
Best guess is the emmissions vacuum port but it usually has a small tube sticking out of it. I had the same question a while back and posted this thread - see if it helps. https://www.ford-trucks.com/forums/s...d.php?t=404114
Old Nov 21, 2005 | 09:34 AM
fordborn's Avatar
fordborn
Thread moved to "221, 260, 289, 5.0/302, 5.8/351W V8" forum. Should receive more help to the question here.
Old Nov 21, 2005 | 04:02 PM
fivestring63's Avatar
fivestring63
That is the same port mine had a ton of emissions hoses hooked to, including the vacuum advance. I rebuilt the carb and did away with all that crap and hooked the vacuum advance into this port. Is this a good port to hook it too??
Old Nov 21, 2005 | 05:55 PM
Franklin2's Avatar
Franklin2
Check the port for vacuum at idle. If it has vacuum, you need to move the dist hose to one that only has vacuum when you rev the engine.
Old Nov 21, 2005 | 06:08 PM
fmc400's Avatar
fmc400
MSEE
That port often supplies ported vacuum to the EGR system. These ports usually have a stem to hook a vacuum line to. Does it run through all the way to the throttle bores? It might be soldered shut.
Old Nov 21, 2005 | 10:52 PM
rfxj3's Avatar
rfxj3
The vacuum port for the ignition advance on a 2100/2150 is located on the right(passenger) side of the carb just in front of the throttle bore at the base of the carb.
Old Nov 22, 2005 | 01:12 AM
rfxj3's Avatar
rfxj3
Just saw where someone posted a great picture that labels all the important stuff on these carbs. https://www.ford-trucks.com/forums/s...hreadid=432251
Old Nov 22, 2005 | 10:37 AM
1bad73bronco's Avatar
1bad73bronco
I have the same thing on my 73 bronco...Its plugged with a short section of hose with a screw in the end of it
