03 vent problems
Old Nov 19, 2005 | 11:07 PM
Kenneth Brown's Avatar
Kenneth Brown
03 vent problems
I know its getting to be the wrong time of the year for this but....... If I turn the ac on max or the vent section it doesn't seem to blow out there. It does however blow out of the defrost ducts. I am understanding that this is a "default" setting due to low vaccum. I have "tested" this theory out by letting of the gas pedal quickly and coasting. Sure enough most of the time it will start coming out the corect vents. Any idea on how to fix?
Old Nov 20, 2005 | 01:46 AM
ford390gashog's Avatar
ford390gashog
do you have a check engine light on? because if it is a engine vacuum leak it would run real rough. my guess is someone pulled the hoses off with their feet . it is very easy to do . i would pull the panel and look for disconnected hoses.
Old Nov 20, 2005 | 09:28 AM
Kenneth Brown
No check engine light. It runs great, no misses, no lack of power,everything seems fine.
Old Nov 21, 2005 | 06:46 PM
Kenneth Brown
Anybody else have any suggestions?
Old Nov 27, 2005 | 06:44 PM
Kenneth Brown
******Bump******
Old Nov 27, 2005 | 09:09 PM
AwesomeBullet's Avatar
AwesomeBullet
I don't know where it is..But there is a check valve in the system somewhere. Ford used to put it close to the battery. Just follow the vacuum line that goes through the firewall to the dash. Start at the firewall and work your way back to the engine, you will find it. Either the check valve has failed or the vacuum line has broken....
raye321
Aug 1, 2014 06:20 AM
pickupman2002
Sep 24, 2012 02:37 PM
wgm114
Aug 12, 2012 09:24 PM
wgm114
Aug 6, 2012 06:04 AM
speedyg
Apr 8, 2004 06:03 PM
