Brake Troubles
Old Nov 19, 2005 | 06:19 PM
TXranger2003's Avatar
TXranger2003
Unhappy Brake Troubles
I have a 2003 ranger 2wd 4cyl. the brake pedal is hitting the floor when i press on it. i know i need to bleed the brake system but i dont know how? any info on the procedure for this would be greatly appreciated. Thanks....
Old Nov 19, 2005 | 06:29 PM
JD717's Avatar
JD717
this is a task best suited to two people, one to sit in the cab and pump the brakes, the otehr to open the bleeder valves at each wheel and let air out.
You'd be best to have a manual to read for better info than I can give on this task.
Old Nov 19, 2005 | 10:00 PM
el conquistador's Avatar
el conquistador
go to autozone.com and they have the procedure there.
Old Nov 20, 2005 | 10:31 AM
TXranger2003
thanks guys
