What Exhaust do I need?
Old Nov 19, 2005 | 06:14 PM
FX4Range R's Avatar
FX4Range R
I was wondering what exhaust size do I need. Right now I have a 2.5in piping with headers and a Y Pipe with no cats, 75mm maf and a chip and a K&N FIPK. But I have the EE Kit ordered and was wondering if my exhaust is sufficient or do I need to upgrade to a 3in piping?
Old Nov 19, 2005 | 06:22 PM
RangerPilot's Avatar
RangerPilot
What exactly does the EE kit do? Unless it's creating massively more horsepower and torque, and I doubt it, you're 2.5 will be just fine. What engine are you runnin'?
Old Nov 19, 2005 | 07:13 PM
FX4Range R's Avatar
FX4Range R
The EE kit is a S/C kit from Explorer express. http://www.explorerexpress.com/ Its not forwarding the link once you click on it so just type it on your browser. Instead it goes to motorhavens site. Whats up with that?
I have a 02 Ranger FX4 4.0 Sohc 5 spd.
Old Nov 19, 2005 | 07:30 PM
Ken00's Avatar
Ken00
They should be able to tell you the proper diameter for the exhaust.
Old Nov 20, 2005 | 08:26 AM
BigBlue88's Avatar
BigBlue88
Flow restriction (backpressure) is greatly dependent on the length of the pipe; a short(er) 2.5" pipe will have similar backpressure to a longer 3", and have the added benefit of high gas velocities (which helps scavenging and torque). If you want cheap & easy exhaust backpressure decreases, just shorten your existing exhaust (dumps behind the cab?).
Every S/C vehicle I've heard has a dramatically different exhaust note than their N/A counterparts- smoother, mellow, deeper. A short exhaust on your S/C Ranger with your favorite muffler might sound really good.
Old Nov 21, 2005 | 07:54 PM
FX4Range R's Avatar
FX4Range R
Well the only thing I dont like dumped exhaust is that its going to be really loud in the cab. But I will give it a try once I get my S/C, If I dont like it, looks like I will have to go 3in piping.
Old Nov 21, 2005 | 07:59 PM
BigBlue88's Avatar
BigBlue88
Adding a long (25") perforated-core glasspack will go a long way towards quieting the sound. I'd probably put it after the main muffler.
Old May 21, 2006 | 08:37 PM
andy6432668's Avatar
andy6432668
I always run straight pipe from cat back louder than muffler but not to loud as long you run it all the way to rear of truck would be loud if short pipe.
Old May 21, 2006 | 09:36 PM
RangerPilot
Wow...kinda an old topic to dig up don't you think?
RP
Zach
Old May 22, 2006 | 09:14 AM
bigdavesohc's Avatar
bigdavesohc
Unless you get a cheap, loud muffler, cab volume is nothing to worry about. If you want to dump under the truck, just get a piece of pipe and run it all the way to the axle. That should make it quieter inside.
Old May 22, 2006 | 06:23 PM
RangerPilot
I'm sure he has the exhaust by now... If you're going to dump it though, definetly do it further back (like behind the axle) so you don't have fumes in the cab.
RP
Zach
