Engine ID / Alternator Install Issue
Old Nov 19, 2005 | 01:31 PM
Boydness's Avatar
Boydness
Question Engine ID / Alternator Install Issue
Can someone please ID the engine that the PO installed:
https://www.ford-trucks.com/user_gal...&albumid=19007
When I first got it, the alternator was not installed, basically it was just hanging there with a single bolt. Well, it's now a year and a half later, and I finally start putting everything together and guess what... The chrome alternator backet that I purchased (just like on my 289) does not want to bolt onto this 302.
You can see that the water pump inlet is on the driver's side (versus the passenger's on the 289), although I thought that the 289 and the 302 use the same SB Ford alternator bracket. Am I wrong?
The waterpumps are obviously shaped different were the bracket should mount. The 289 uses the 1/2" x 1 5/8" spacer at the top to mount and the two bolts on the waterpump, but I do not have any of the same mounting holes on the 302. The top hole on the 302 block is larger than the 289's hole.
I would appreciate any help or ideas.
Boyd
Old Nov 19, 2005 | 07:51 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Nov 19, 2005 | 08:16 PM
Franklin2's Avatar
Franklin2
Some of the 302's I have had used a insert in the large hole. This reduced the size of the large hole down to fit the bolt for the alternator. I have seen several like this, so I believe they come from the factory this way. Can you buy a new one? I don't know.
As far as the bracket, if you can't make it fit, I would get a bracket that is for the body style the engine is installed in. I am assuming whatever you have put this engine in, has the original radiator which requires the waterpump inlet on that side. So if you find a bracket for that model, it should fit that style waterpump(theoretically).
Old Nov 20, 2005 | 12:09 AM
baddad457's Avatar
baddad457
Ford used about ten(maybe more) diffferent waterpumps and timing cover combinations over the 40+ year run of the small block. Some will interchange accessories, some won't. To bolt up the alternator try removing that aluminum adapter bolted to the head, otherwise you're going to possibly need the the accessory brackets that work with that waterpump/timing cover combo.
93PGT
38
Mar 6, 2008 10:42 PM
preppypyro
37
Apr 22, 2007 10:53 AM
HarryD001
Nebraska Chapter
Mar 24, 2006 09:43 AM
hoff
Indiana Chapter
Sep 8, 2004 10:19 PM
