Explorer-dying idle when cold
Old Nov 19, 2005 | 09:40 AM
beemr's Avatar
beemr
I have a 2000 Eddie Bauer Explorer. The check engine light is on, and when getting the state inspection, the tech said it gave a code other than emissions, so it passed...but he could not say what specifically was the problem.
When started cold, it barely idles and wants to die unless you feather the throttle. I am assuming it is a high idle/cold idle valve or solenoid. Once it gets warm, it runs fine except for the check engine light.
Does anyone know what it might be or where to look?
Thanks...
Old Nov 19, 2005 | 09:46 AM
FortyFords's Avatar
FortyFords
Idle air control valve(IAC )silver canister on the throttle body change it or clean it
Rich
Old Nov 19, 2005 | 09:50 AM
beemr's Avatar
beemr
Thank you...I will try it post with.....
Old Nov 19, 2005 | 10:04 AM
FortyFords's Avatar
FortyFords
Iwould get the vehicle scanned for the code!let us know what the code is and we can
help from there.
After thinking about this I'd get it scanned first.it could be a vacum leak (unmetered air in the intake )
Yes scan it first.
Rich
Old Nov 19, 2005 | 12:06 PM
srercrcr's Avatar
srercrcr
While youre doing the IAC motor, clean both sides of the throttle plate just inside the snorkle.
