Just a little trick to safely clean your engines oiling system...... I ran some Rotella 15W-40 in my 360 for 2 oil changes to clean it out. It worked better than expected!! A lot of people assume 15W-40 is for diesels only, it's not. It has more detergents and anti-soot additives in it than regular oil, so it will give your motor a nice little internal bath!!! Just wait until you have warmer weather to do it, because you don't want to run a fairly thick oil in cold weather. My oil went from being black after 1,000 miles, to a nice amber color
at 3,000. Just run 15W-40 for 2 oil changes, changing the oil around 1,500 miles. Then resume using your regular oil.
"Don't Laugh At This Truck Mister, Your Daughter Might Be In Here!!"
'78 F250 4x4/351w/NP435/NP205
lifted/"35 mudders
'78 F100 2wd/360/C-6/"9 inch
4bbl int carb
