Pulling own codes
Old Nov 22, 2005 | 12:04 PM
qman's Avatar
qman
They there's something wrong with your EVP. It's easy to test. Again, read my thread and see what I did. The vacuum pump will allow you to determine if you have 1) enough vacuum to the EGR and 2) if your EGR reacts to vacuum correctly. You can fix either one of those easily enough. If it's not either of those then it could very well be the EVP itself or the connection to it.
